Like Tree1Likes
Old 03-19-2017, 10:16 AM
Send a message via AIM to Carmotive Send a message via MSN to Carmotive
Default Bought this cobra need help identifying its origin
I recently acquired a replica cobra with very little history. It is missing the decal from the company that built it. There has many characteristics that make it unique. I am hoping someone here can help me identify where it was built. It seems to be a early 80s build. It has a 427 with Weber 8 stack. Custom billet air cleaners. Brass inserts in the valve covers. Brass bumpers. Brass shift bezel. The gauges are from classic instruments with brass bezels. Chrome spoke knock off wheels. Electric Brake vacuum pump. Side pipes that are removable with one Alan bolt. It seems to be built extremely well and designed to actually be raced, not just a conversation piece or Sunday cruiser. It has a 8 digit assigned Arizona vin number. Any help is appreciated. I have attached as many pictures as allowed.
Old 03-19-2017, 10:20 AM
More pics
Old 03-19-2017, 11:16 AM
BDR0572's Avatar
Cobra Make, Engine: BDR, Roush 402R
(It has a 8 digit assigned Arizona vin number) I would start there research the VIN
Old 03-19-2017, 11:54 AM
MaSnaka's Avatar
Carmotive,
Welcome to the madness. What you describe as identifying details are mostly accoutrements that could have been selected by the original builder. True identifiers would be frame and suspension details, under the hood and trunk, pedal box. Someone should recognize your make.
Old 03-19-2017, 12:28 PM
Thanks for the info! I was planning on getting it on the hoist tomorrow. I will take more pics and post them.
Old 03-19-2017, 05:16 PM
Old 03-19-2017, 06:05 PM
If it were that easy I would not have posted.
Old 03-19-2017, 06:28 PM
Good luck with your search.
Old 03-21-2017, 03:31 AM
Default More pics
The block has screw in freeze plugs and cross bolted crank. The tag on frame says Copperstate 005. Any help is appreciated.
Old 03-21-2017, 03:39 AM
Default Pics
See pics
Old 03-21-2017, 05:44 AM
Buzz's Avatar
While I don't claim to be able to recognize and identify a Corvette chassis and underpinnings, my guess based upon the apparently stretched wheelbase, near vertical windshield and heavy steel production car chassis components, is that the car is a Cobrette. Produced by a company that sold a cobra-like body conversion for C3 (and later) Corvettes. The difficult to read tag which appears to be double stamped looks like it could say Cobrette if I squint and tilt my head just right.
redmt likes this.
Tropical Buzz
Old 03-21-2017, 06:01 AM
The tag says "copperstate - 005"
Old 03-21-2017, 07:01 AM
I would think that most any decent welder could tell the difference between robot welds and hand welding. hat could give you a clue as to whether or not it is a modified "factory " frame. GM has notoriously funky welds.
Old 03-21-2017, 07:17 AM
Buzz's Avatar
I stand corrected on the tag, and the frame welds look pretty good to my amateur eye, so my guess could well be wrong. Wouldn't be the first time and it probably isn't gonna be the last
There's not much to go by in the pics, but can anybody tell what the rear suspension looks like? Looks like an IRS unit with outboard brakes so not Jaguar based.
Also - have you measured the wheelbase? Is it more than 90 inches?
Edit - One more question: Is that roll bar attached through to the frame or does it bolt directly to the body?
Tropical Buzz
Old 03-21-2017, 08:33 AM
Tommy's Avatar
Just an observation: Copper State is the nickname for Arizona, and the Cobrette is/was made in Arizona.
Tommy
Previously owned EM Cobra
Old 03-21-2017, 10:22 AM
Tjd Tjd is offline
Looks like a copper state cobra from the early 80s as MGB Front crossmember
Old 03-21-2017, 10:23 AM
I'm curious. Might I ask what you paid for it?
Old 03-21-2017, 10:30 AM
DanEC's Avatar
I can see just enough of the rear suspension to say it looks like a late C3 Corvette IRS - after they went to the aluminum truss cross member support. It looks like coil overs have been substituted for the leaf spring. Can't be sure but the truss member and differential housing shape appear Corvette.
ERA 782 Running
Old 03-21-2017, 11:15 AM
MOTORHEAD's Avatar
According to Tjd, there was a "Copperstate" Cobra (obscure yes, but there are/were many Cobra builders like that) Appears to be sn 005. Google search warranted !
"When Injustice becomes Law,
Old 04-21-2017, 12:56 AM
kris-kincaid's Avatar
Cobra Make, Engine: 427 SC
Send a message via AIM to kris-kincaid Send a message via Skype™ to kris-kincaid
I'm not certain at all about the origin of your car but I remember Roy Hunt from the Finishline Shelby dealer telling me that in the 1980's he owned a Cobra replica company called Copperstate Cobra's.
Tags
427, identify, side oiler
