Old 05-07-2017, 04:19 AM
Cobra Make, Engine: AC289 sports
Default Armstrong Coil over shocks
Does anyone have any info on the Armstrong shocks fitted to the AC289 sports Images or specs
All i know is the Sprins had a 4,1/2 in diameter with a wire diameter just over 2in with Front 10 coils the rears were the same but only had 8 coils..
Mark
Old 05-11-2017, 07:56 AM
I have found the Armstrong parts numbers...
63-65....Front S S62-3180A Rear S64-2130A
65-67 427&289 S65-0430A Rear S65-0440A
67-69 427&289 S65-0430A Rear S65-0945
Does anyone have any period photos or measurements for these Shock's
Old 05-11-2017, 08:26 AM
LMH's Avatar
LMH LMH is offline
So the Cobra 427 and AC 289 Sport share the same shock?
Alba gu brąth
Old 05-12-2017, 01:33 AM
According to the Rinsey Mills, AC Ace & Cobra, yes.
Old 05-12-2017, 01:41 AM
It seems that way.. According the Rinsey Mills book AC Ace & Cobra yes,
As the 289 sports Used the 427 chassis and street body, surely it goes without saying most if not all of the suspension components were shared as well, ??Apart from he front springs??
The Armstrong PDF lists AT11 heavy duty shocks, I still need to find out if it was the Commercial Blue range.
Old 05-12-2017, 06:24 AM
Dan Case's Avatar
Original Shelby Owner
Mark,
Thanks for sharing the catalog information but the 1963-65 Cobra (leaf spring chassis) units made during the manufacturing period are not stamped with the identification numbers you have posted above. The catalog page shows two sets of numbers, the current at time of publication numbers and under that another set of numbers in parenthesis. The text listed in parenthesis correlate with what was actually stamped on the bodies of assemblies. If you are going hunting based on part numbers you probably need find samples of exactly what you want and determine what part numbers were stamped into them and if different than what is in your catalog quote both new and old part numbers.
Dan
Samples of identification text as exhibited on original Cobra production units during the CSX24xx chassis range are below:
Rear sample:
TYPE AT9/GS 215 8
Front sample:
TYPE A.T.9/ 2 7 98
Dan Case
Old 05-12-2017, 07:04 AM
Just being lazy... ;-) I should have posted both sets...
AT11's for the 289S and 427 have come up with what i need for now but no dimensions tech specs as yet..
Old 08-10-2022, 04:42 AM
Default Original 427 Dampers
Hi all, did the original 427 Armstrong or Koni dampers have adjustable spring platforms? If so, any chance anyone has a photo of them, preferably on the car, showing the spring platforms?
