Like Tree5Likes
  • 1 Post By morgy
  • 1 Post By Dan Case
  • 2 Post By Dan Case
Old 05-15-2017, 10:06 AM
Cobra Make, Engine: AC289 sports
Default 1965-66 PCV Valve
Where there different types in the PCV valves fitted to Late AC289S/Cobras?
I have seen some Autolite PCV's with a threaded top using the 90 brass adaptor and some with push fit top with the pipe clamped on..
Were these units a standard Mustang part for 66 engines, fomoco part number or still Autolite?
Also the the Oil filler and PCV seem to swap sides on different cars, What is the correct side when using a 289 McCord surge tank..... PCV on the left side (LHD drivers side)
1985 CCX likes this.
Old 05-15-2017, 10:39 AM
LMH's Avatar
LMH LMH is offline
That brass elbow/pcv setup was used on leaf springs cars but I'm not sure what was used on the later AC289 cars. There was one of the brass elbows just a couple weeks ago on eBay but I didn't buy it. I have 3 and that's my limit for spares!
Alba gu brāth
Old 05-15-2017, 11:29 AM
Dan Case's Avatar
Original Shelby Owner
Check out this new car road test I found online.
https://www.flickr.com/photos/trigge...7632489228700/
Dan Case
Old 05-15-2017, 04:11 PM
rsk289's Avatar
Yep, that's Motor's road test of 14th Oct 1967. Not sure who wrote it, but it's reproduced in Brooklands Books' Shelby Cobra Gold Portfolio, 1962-1969, compiled by the estimable R M Clarke.
Old 05-16-2017, 01:47 PM
Dan Case's Avatar
If any other 289 Sports fans are reading, after the original post I did some hunting and found that AC Cars Ltd apparently used both 1965 made and 1966 made HP289 engines in the small number of cars completed. The three engine assembly dates I recorded to date are 5A22, 6D12, and 6D13.
There were model year variations between engine assemblies, i.e. the parts making assemblies up. That so, I would not expect the exact Ford engine components used on all 289 Sports that were completed.
1985 CCX and LMH like this.
Dan Case
Old 05-16-2017, 03:51 PM
Cobra Make, Engine: genuine 289 cobra (cox 6013)
5A-21 also !!!
Bernie
Old 05-17-2017, 01:35 AM
Thanks Dan..
The photos I have of the Bible show the same info, Typically mine has no code entered in the Bible!!....
Old 05-17-2017, 09:59 AM
Dan Case's Avatar
Originally Posted by BERNIE View Post
5A-21 also !!!
Bernie
Not a lot of information is in the public domain but what is shows that AC Cars installed five and six bolt engines in chassis; engines made in batches between early 1963 and the third week of April 1966. Not that is helps Mark in his quest in any way but information in public includes:
Leaf Spring COB/COX60xx chassis
COB6008 = 1670 (early Ford five bolt HP289 serial number)
COX6010 = 1657 (early Ford five bolt HP289 serial number)
COX6014 = 2559 (Ford five bolt HP289 serial number)
COB6024 = 3135 (Ford five bolt HP289 serial number)
COB6026 = 3184 (Ford five bolt HP289 serial number)
COX6032 = 3204 (Ford five bolt HP289 serial number)
COB6039 = 5413 (late Ford five bolt HP289 serial number)
COB6040 = tag not stamped
COB6046 = tag not stamped
COB6054 = 5A27Z (Probably a Ford six bolt assembly date January 27, 1965. I say probably because only six bolt engines were made in standard production after July 1964. There is a chance, I would believe it to be real small, that it could have been a five bolt “service” engine. Small numbers of HP289 service engines were assembled using what parts were available at the time after five bolt engine standard production ended. I have no idea if five bolt HP289 service engines were being made past August of 1964 as in September 1964 several of the components in all 289 engine assemblies changed to new design revision levels. )
Coil Spring COB/COX61xx chassis
COB6105 = 5A22F (probably a Ford six bolt assembly date January 22, 1965)
COB6120 = 6D13F (Ford six bolt assembly date April 13, 1966)
COX6122 = 6D12F (Ford six bolt assembly date April 12, 1966)
COX6126 = shipped to original owner without engine or transmission
COB6217 = chassis not completed and sold less engine
The Ford serial numbered five bolt engines span an early 1963 to summer of 1964 production time frame. The 5A22 and 5A27 made engines had to be 1965 model year assemblies while the 6D dates represent a 1966 model year engine model.
It would be fantastic to come up with day one pictures of these January 1965 engines in these chassis get a look at the clutch bell housings. A good picture of a bell housing would allow visual identification of its five or six bolt design.
Dan Case
Old 05-17-2017, 03:12 PM
COB 6047 five bolts, 5A21R tag
Old 05-30-2017, 06:13 AM
Any one have a copy of Bob Manel's book that could tell me the part number for the Non shellby HiPo 289 PCV valve. From some photos i have i can just make out it is a non threaded type with the vent pipe pushed on with a circular spring clamp around it...
Old 05-30-2017, 10:04 PM
LMH's Avatar
LMH LMH is offline
C5AE-6A666-A
Mr. Mannel's book also says C5AE-6A666-B and C5AE-6A666-C were other possible numbers.
Alba gu brāth
Old 06-11-2017, 06:47 AM
Would this have the same part number for a 1966 engine with a 6D13M assembly date code?
