Old 06-13-2017, 01:07 AM
rsk289's Avatar
Default Greasing
Just a quick service question - when greasing leafspring suspension (every 500 miles, it says in the manual), do owners jack up to take the weight off the suspension, or leave the car on the ground?
Old 06-13-2017, 10:47 AM
LMH's Avatar
LMH LMH is offline
I would say it should be jacked up for joints that are under weight with the car on the ground.
Alba gu brąth
Old 06-13-2017, 11:49 AM
1795's Avatar
Are you talking about greasing the steering components, i.e., ball joints, or are you referring to greasing the transverse leaf springs?
Old 06-13-2017, 11:59 AM
rsk289's Avatar
Springs and front trunnion/ball joint, principally. I guess jacked up makes most sense, as you say Larry.
Old 06-13-2017, 12:20 PM
1795's Avatar
Would be a pain to grease them with the car not jacked up.
Old 06-13-2017, 12:23 PM
rsk289's Avatar
They're quite easy to get to via my inspection pit, but obviously even easier with the wheels off.
Old 06-13-2017, 02:26 PM
LMH's Avatar
LMH LMH is offline
Probably better for the half-shafts too. Getting grease with the rear at full droop extends the shafts.
Alba gu brąth
