Old 08-06-2017, 03:48 AM
xb-60's Avatar
Default Tecalemit grease gun
Does this look correct....?
It's around 140mm long and 28mm diameter.
Glen
Old 08-06-2017, 07:13 AM
Dan Case's Avatar
Original Shelby Owner
As original to a Cobra or 427 Cobra sent to America, not that I can see in that picture.
The old thread in the AC Owner's Club site has been lost in a website incident but I created a album in this forum to put some of my images in.
AC Cars supplied grease guns - Club Cobra Photo Gallery
Also because there are multiple taper tip adapters I will add an extra comment on nozzle tips. The ones I expect for USA Cobras and 427 Cobras utilize the small diameter cone that cups grease fittings with a taper at the end with a circumferential groove cut around the straight section near the taper. (There is a similar tip without the groove.)
I have examined, have, or have had ones with
• two different length body cylinders
• three different closed ends, two different pleated versions and a round cap design
• several different adapter tips, some tips could be ones owners swapped in somewhere along
• two different "GB 2800" embossed caps, i.e. both marked GB 2800 but they are embossed with two different patent numbers
• different colors/type of pain on the cylinder bodies depending on body design
Dan Case
Old 08-06-2017, 05:48 PM
xb-60's Avatar
Thanks Dan. As always, excellent information.
Glen
Old 08-07-2017, 07:46 AM
Dan Case's Avatar
You are welcome.
Dan Case
