21Likes
07-30-2018, 12:56 PM
Works of art!
07-30-2018, 03:42 PM
Full Blown Member
Bravo!
Those should make some people happy.
rodneym
07-31-2018, 08:29 PM
Originally Posted by Armrer
Thanks, guys. I did a small run of these, so they will go fast. First come, first served. Knobs are included, but I wont sell them separately.. I have just enough for the tracks themselves. Every detail of the original Leverolls are captured.. slight misalignment of spot welded brackets, Leveroll ID stamping, Aerotight lock nuts, etc., etc. I will respond to you later today.
Thanks for the post, Larry!
Jeff, did you get my PM?
Ed
08-01-2018, 03:08 AM
Ill take a pair.
Worked out after all.
08-01-2018, 11:15 AM
n/a
PM sent, Jeff!
Roger
08-01-2018, 09:12 PM
Hey guys, one thing I did want to point out is these are not the knobs currently for sale on eBay. These are accurate reproductions in every way with the correct base radius, top facets and all correct angles. Once you compare at the two, you'll see what I mean.
Alba gu brąth
08-02-2018, 09:38 AM
IL
Larry the knobs and the lever on the new made tracks look different in the pictures you posted . The knob looks longer and the lever looks to be a smaller dia and doesn't look to have a step down to where the thread starts. I also see other differences.
08-02-2018, 10:04 AM
I see what you’re saying about the knobs but it’s the photograph that’s making it look like that. I held a new knob and and an original knob in my hand and compared the two side by side. They’re the same except for wear on the facets of the original knob. I have the master used for the casting, machined from a technical drawing.
Alba gu brąth
08-02-2018, 02:54 PM
Cobra Make, Engine: SPF 289 Street
MA Stuart,
Mmm, levers/ Knobs are identical in all dimensions to Original Equipment. I think the iPhone pics are a little stretched in the distance. I sent Larry closeup pics of new shaft and old for comparison, I’m sure he will post later-
08-02-2018, 03:11 PM
IL
Hey guys don't get me wrong they look very good. I
was just saying in the pictures Larry posted the levers and knobs looked longer
08-02-2018, 03:26 PM
No worries  That's a valid point, and the close up pix will show the initial pic was distorted. All good-
08-02-2018, 04:27 PM
I’ll post them this evening when I get home. I should have taken pics of the old and new knobs side by side but I don’t think I did. I’ll check though.
Alba gu brąth
08-02-2018, 07:55 PM
Here's the two levers, original and reproduction. Same diameter as original and machined step in threaded portion.
Alba gu brąth
08-09-2018, 08:39 AM
I’ve had a couple inquiries about the finish on the tracks. So FYI, they’re plated, not painted.
Alba gu brąth
08-09-2018, 10:35 AM
Check's in the mail
08-09-2018, 10:37 AM
Cobra Make, Engine: Superformance. 427 Windsor.
Beautiful, cost and availability please. Just when I thought that I was almost done!
08-09-2018, 10:41 AM
n/a
Looking forward to these, thanks Jeff.
One question though - does anyone know how these fix to the chassis? I know the mounting holes should line up with the 'U' section outrigger supports under the ali floor pans, two each side. But when I've tried to fit originals before the inner mount positions are impossible to access due to the main chassis tube position (chassis's a Kirkham - same dimensions as original AC). Is there a trick to this - am I missing something?
Jeff, do the new ones come with threaded studs for mounting to the floor, or do we need to use machine screws?
08-09-2018, 10:47 AM
Wa
Cobra Make, Engine: ERA 3012
Check went out yesterday -- really looking forward to these! Jeff, great talking to you the other day. Thanks again to both you and Larry!
08-09-2018, 11:22 AM
CH
Unfortunately I did not get the details as requested on my PM.
Could you please tell us the price for a set?
Driving with your Cobra is fun,
Racing with your Cobra is amazing,
Driving hill-climbing races with your Cobra is.... HAVEN!!
08-09-2018, 11:25 AM
CH
double post
