Old 05-10-2006, 10:20 PM
LMH's Avatar
LMH LMH is offline
Default Motor Mounts on Original S/C's
Hey all,
I was looking at a photo of my favorite original (CSX 3014) and noticed that where they come through, the headers are VERY close to the body.
I would think the rocking of the engine would cause the header to hit the body. Did the original's use solid motor mounts?
Old 05-10-2006, 11:13 PM
Specialk's Avatar
Cobra Make, Engine: 427 SC
Send a message via AIM to Specialk Send a message via Skype™ to Specialk
No, they used rubber mounts. The headers probably do touch the body when the car is at full throttle.
kris kincaid
Old 05-11-2006, 01:58 PM
LMH's Avatar
LMH LMH is offline
Thanks Kris!
Old 05-11-2006, 03:22 PM
This is what we do on the high-horsepower cars.
Old 05-11-2006, 10:13 PM
LMH's Avatar
LMH LMH is offline
I already had planned on doing that to my mounts.
Thanks for the link!
Old 07-26-2006, 05:20 AM
Dominik's Avatar
good morning,
as a matter of interest, cold the engine be mounted solid?
well, I did, and didn't consider the vibrations to be severe enough to bother me.
It does stengthen the chassis, doesn't it?
Dominik
If I don't respond anymore, that's because I can't log in
Old 07-26-2006, 09:02 AM
LMH's Avatar
LMH LMH is offline
My brother is using solid mounts on his FFR, has had zero trouble and now swears by them. He doesn't notice any more vibration than when he used poly mounts.
Old 08-30-2006, 07:14 AM
Cobra Make, Engine: shell vally
Default motor mounts
Help I have a shell valley car that had a 427 in it. I purchased the car without the engine and am replacing it with a early modle 390 that has two holes for the mounts to bolt to. I have tried four sets of mounts and none work. Can anyone help?
Old 08-30-2006, 10:16 AM
Terry Stapley's Avatar
Cobra Make, Engine: Shell Valley, 418W, tremec 3550tko, 9" ford rear, 3.0 gear, silver/black
Joron,
Call Dana at Shell Valley, he will know which part # you need.
888-246-0900
Terry
Old 09-01-2006, 12:42 AM
In an attempt to get this thread back into the "Originality Forum", I believe that original cars used two bolt motor mounts, even though the blocks had provisions for three.
Old 09-01-2006, 06:13 AM
CC Member / Sponsor
Original 427 coil spring cars (comp, SC and street) used the C1MM mount. This mount is very rare. It has a different offset than the Buffalo and Anchor mounts that are available at NAPA, etc.
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
