05-10-2006, 10:20 PM
Motor Mounts on Original S/C's
Hey all,
I was looking at a photo of my favorite original (CSX 3014) and noticed that where they come through, the headers are VERY close to the body.
I would think the rocking of the engine would cause the header to hit the body. Did the original's use solid motor mounts?
05-10-2006, 11:13 PM
NV
Cobra Make, Engine: 427 SC
No, they used rubber mounts. The headers probably do touch the body when the car is at full throttle.
kris kincaid
05-11-2006, 01:58 PM
Thanks Kris!
05-11-2006, 03:22 PM
This is what we do on the high-horsepower cars.
05-11-2006, 10:13 PM
I already had planned on doing that to my mounts.
Thanks for the link!
07-26-2006, 05:20 AM
good morning,
as a matter of interest, cold the engine be mounted solid?
well, I did, and didn't consider the vibrations to be severe enough to bother me.
It does stengthen the chassis, doesn't it?
Dominik
07-26-2006, 09:02 AM
My brother is using solid mounts on his FFR, has had zero trouble and now swears by them. He doesn't notice any more vibration than when he used poly mounts.
08-30-2006, 07:14 AM
GA
Cobra Make, Engine: shell vally
motor mounts
Help I have a shell valley car that had a 427 in it. I purchased the car without the engine and am replacing it with a early modle 390 that has two holes for the mounts to bolt to. I have tried four sets of mounts and none work. Can anyone help?
08-30-2006, 10:16 AM
UT
Cobra Make, Engine: Shell Valley, 418W, tremec 3550tko, 9" ford rear, 3.0 gear, silver/black
Joron,
Call Dana at Shell Valley, he will know which part # you need.
888-246-0900
Terry
09-01-2006, 12:42 AM
In an attempt to get this thread back into the "Originality Forum", I believe that original cars used two bolt motor mounts, even though the blocks had provisions for three.
09-01-2006, 06:13 AM
CC Member / Sponsor
UT
Original 427 coil spring cars (comp, SC and street) used the C1MM mount. This mount is very rare. It has a different offset than the Buffalo and Anchor mounts that are available at NAPA, etc.
