Like Tree13Likes
Old 06-07-2019, 06:59 PM
Originally Posted by beemerb0y View Post
Anyone get a bird flying in there? Sorry had to ask
Yep, and the bird's name is, of course, "Flip."
Old 06-07-2019, 07:20 PM
LMH's Avatar
LMH LMH is offline
A single fan mounted in front of the radiator is original. Dual fans aren't original.
And yes, I know it's an old thread.
Alba gu brąth
Old 06-17-2019, 07:24 PM
Cobra Make, Engine: Superformance , Roush 427SR dyno'd at 526 hp
Default Twin pusher fans
Originally Posted by double ugly View Post
A lot of cobras have them. I think in warmer climates it is a benefit as long as a puller fan is behind the radiator. I think it also adds to the "cool" factor. No pun intended. John
I know this is an old post but I want to add the twin fans to my Superformance Cobra for looks only. Where did you get your fans? Thanks Lou
Old 06-18-2019, 02:07 PM
Cobra Make, Engine: NAF 427
I like the look of the pusher fans on my car:
I used fan motors and fan blades from McMaster Carr but both are available from Finishline and others.
The pusher fans work just fine keeping the water temp at 185 at about 80 to 85 deg air temp in slow traffic.
In stop and go traffic or hotter temps I use my puller fan to keep things at 175 to 185 water temps.
I use a three position toggle switch: OFF/pusher fans ON/ pusher fans OFF - puller fan ON
And relays and temp ON?OFF sensor in case I'm not watching the temp gauge.
The pusher fans are also big hits at the car show.
Greg
Old 06-20-2019, 04:42 PM
1985 CCX's Avatar
I added a touch of old school break in fan look.
They work well but I have a small block with a big radiator.
LMH and xb-60 like this.
Old 06-21-2019, 10:47 AM
cycleguy55's Avatar
Man, those must be some sticky tires. Avons? LOL
1985 CCX and Gaz64 like this.
Brian
Old 06-21-2019, 11:59 AM
LMH's Avatar
LMH LMH is offline
Did you properly dip those in yellow safety paint Jeff?!!
1985 CCX likes this.
Alba gu brąth
Old 06-21-2019, 09:31 PM
pgermond's Avatar
[IMG][/IMG]
Gaz64 likes this.
Phil
http://www.uniquecobra.com/
Old 06-22-2019, 03:14 AM
RB60's Avatar
Cobra Make, Engine: Unique Fresh 427 S/O
Originally Posted by pgermond View Post
[IMG][/IMG]
I have the same setup you do with the puller on my Unique. Even in heavy traffic, it hasn't gone over 190.
Not to go off topic, but your link to the Uniqueforums brings up an error for me, has for months and I'm a member. Just wondering if it does for others.
Old 06-22-2019, 09:11 AM
pgermond's Avatar
RB60,
I Installed a puller behind the radiator also, the pushers don't to the job in the summer where I live. The link works fine for me.
Phil
Old 05-10-2020, 11:43 PM
mjhcobra's Avatar
Cobra Make, Engine: Everett Morrison, 428
Hi Guys,
I am trying to locate fan motors closer to the original style, that I understand were from early Mustangs or Falcons. The size of the Mustang motors are a little longer than the ones currently available from most vendors. Do you know the part number for these fans and who might be selling them?
Also, it appears that the Mustang fan motors are a 2 wire, 3 speed fan. How is this fan wired?
Thanks for your help,
Martin
Old 05-11-2020, 05:56 AM
FWIW, ERA uses a Dayton 3LCH7. Two wires, easy to control via temp sensor in the lower radiator hose, toggle switch on the dash, or both.
  #33 (permalink)
Old 05-11-2020, 08:31 AM
Has anyone here with a Superformance done the same project? I plan to source the parts separately and fabricate my own brackets. But first I'm more interested in seeing how close to the opening they protrude due to the forward facing radiator, as well as seeing how the rod/bracket was mounted to either side? Thanks.
  #34 (permalink)
Old 05-11-2020, 01:52 PM
Somehow I lost your posting today. Send it to me via email and I will get some pics for you
Lou
  #35 (permalink)
Old 05-11-2020, 01:55 PM
Lou
My email address is lou1119@yahoo.com
  #36 (permalink)
Old 05-11-2020, 05:27 PM
Email sent, thanks Lou!
  #37 (permalink)
Old 05-13-2020, 07:47 AM
mjhcobra's Avatar
Thanks patrickt. The 3LCH7 is the motor I currently have. I was able to locate the original Ford motors and determine that the different speeds for the Mustang are controlled thru a resistor, so wiring will be the same as the 3LCH7. The search for originality is always fun.
  #38 (permalink)
Old 05-13-2020, 08:18 AM
FredG's Avatar
Default Fan Install Project
Here is a link to my install including the parts used and how it was wired. You can also check out a post by Patrick for another wiring suggestion. Hope you can glean some ideas from them.
Fred
New Project - Pusher Fans
  #39 (permalink)
Old 05-13-2020, 12:36 PM
mjhcobra's Avatar
[quote=FredG;1476451]Here is a link to my install including the parts used and how it was wired. You can also check out a post by Patrick for another wiring suggestion. Hope you can glean some ideas from them.
Fred
Nice work Fred, looks like your fan project turned out perfect. My fan circuit was designed into my harness from the beginning and it has been waiting for me to get the fans installed. I have a separate switch on the dash with a relay. I do have Lucas switches that have been great so far. We shall see.
  #40 (permalink)
Old 05-13-2020, 01:43 PM
FredG's Avatar
Default I might do a re-wire
Nice work Fred, looks like your fan project turned out perfect. My fan circuit was designed into my harness from the beginning and it has been waiting for me to get the fans installed. I have a separate switch on the dash with a relay. I do have Lucas switches that have been great so far. We shall see.[/quote]
Mine are wired to a separate toggle on the dash to turn them on and off manually. I am having second thoughts about that and may re-wire them to operate off the sensor like the puller does. My Roush 427r never gets hot so I guess they are more for show. They are cool looking though. lol
Fred
