1Likes
Post By Excaliber
09-21-2007, 09:44 PM
Cobra Make, Engine: BRG ERA street car w/428 PI, Sunburst wheels, undercar exhaust, original interior, no philips head screws!
Correct starter solenoid for a 66' car?
autolite or fomoco?
09-22-2007, 03:56 AM
The restorers say:
Up until 1966 - Fomoco ( in script before early 1965, in block letters after early 1965 )
1967-1971 - Autolite
1972 - Motorcraft
09-22-2007, 04:36 AM
Also, if I recall (all my stuff is packed right now), the early 65 solenoid should have the red bakelite finish and the later version (and up) has the black.
Sal Mennella
09-22-2007, 08:28 AM
There ya go Frank they both replied ;-) They've got more information between them than we'll ever be able to use, we'll try though!
09-22-2007, 08:36 AM
It would seem logical they should also utilize BOTH the "I" and the "S" terminal screws. Some solenoids have only the "S" terminal screw.
09-22-2007, 01:35 PM
thanks guys, I appreciate it.
09-22-2007, 02:20 PM
Il
I may be mistaken, but I think the single terminal solenoid that you refer to was only on the ones after they went electronic ignition. The "I" was for
ignition and allowed full voltage to the coil when cranking. Because electronic ignitions generate a spark pulse differently, it's not needed.
WDZ
09-22-2007, 03:09 PM
Thats right Woodzy, the "I" terminal for a full 12 voltage igniton source ONLY when the solenoid is actually engaged (starter turning over). No doubt the original Cobras ran this type of solenoid. Not required or wanted with electronic ignition (depending on the type).
My buddy recently purchased a nice 'hot rod 32 Ford', blown 302, old point type ignition, hard as heck to start. One day he says, "You know a lot of times it starts JUST when I let off the key and quit trying." Then it hit me, I told him check his solenoid, sure enough, he was missing the "I" terminal. He changed it out, ran a new wire and it starts right up every time now.
I think his was RED (as I recall)...
09-22-2007, 03:37 PM
NC
Cobra Make, Engine: CSX 2401 street 289 Cobra and CSX 3288 Street "427" Cobra
The solonoid on CSX 3288 is black with large number 2701966 on the top. (the brown bakelite is underneath the black coating). the car was sent to Shelby from AC in July 1966 and finished by January, 1967. I hope this helps. Jim
