09-25-2007, 04:41 PM
I have a pair of what is supposed to be AC 289 front hubs. I bought them from a man years ago that had a car he was converting to 427 Cobra specifications I believe. They are odd balls in that they are exterior wise dead ringers for rack and pinion leaf spring chassis car hubs except they use the bolt pattern for pin drive, don't have carter key access holes, and if memory serves they don't have the ridge at the flange. Interior wise the bearings are farther apart. I can't say wether or not the bearing spacing is the same as a 427 Cobra because I haven't measured them for comparison. I was hoping to use them since they were already set for pin drive except for the 0.500 counterbores for the pins but original leaf spring car front axles are too short for them. With pins in them they fit into an original Halibrand wheel for leaf spring cars well.
Dan Case
