Like Tree13Likes
Old 04-07-2009, 07:29 AM
ALF's Avatar
ALF ALF is offline
Question Is this car 2075??
Hello
It could be that I'm totally wrong but It looks for me a little bit strange.
Why has this car today 5pin wheels and on the pictures from the 60's ONLY pin-drive's?
http://cgi.ebay.com/ebaymotors/Shelb...1%7C240%3A1308
Is this really CSX2075??
Regards
ALF
Old 04-07-2009, 08:35 AM
Senile Club Cobra Member
The wheels are the rare American mags. They attach to a five pin adaptor that is driven by the splines on the hubs. These were used on DragonSnakes and "Slalom Snakes"
rick@autoventureusa.net
Old 04-07-2009, 08:44 AM
A-Snake's Avatar
Original Shelby Owner
Cobra Make, Engine: CSX2321
Originally Posted by ALF View Post
Hello
Regards
ALF
Not sure of your question? The car appears to have spline drive hubs. The American mags have a spine drive adaptor that is bolted on. Early wheels did not have the exposed lug nuts while later ones have them due to greater strength.
Old 04-07-2009, 09:29 AM
1985 CCX's Avatar
The lugs were added for strength, spline drive were weak thus the addition of lugs. I beleive sline drive wheels were 5 pin in type for an easy conversion.
Old 04-07-2009, 12:32 PM
LMH's Avatar
LMH LMH is offline
Yes, I would say it is really CSX2075.
My registry from 1976 says "original spline type American mags". Also the first car to have a 289 installed at the factory. 260's prior. 2075 is a MkII.
Old 04-07-2009, 01:06 PM
A-Snake's Avatar
Originally Posted by LMH View Post
2075 is a MkII.
Well not exactly. The present 'common' terminology in the states is MKI are the worm and sector cars and the MKII is the rack & pinion cars that began with CSX2126. So in common terms CSX2075 is a MKI.
HOWEVER
The term of MKIII for coil spring cars is a more modern term. AC referred to the coil spring cars as MKII and the leaf spring cars as MKI.
One period use of the term Cobra MKI in a AC brochure appears referring to the discontinued leaf spring cars. From that point the term MKII is used for coil spring cars.
I'm going to stop now before I confuse myself
Old 04-07-2009, 01:51 PM
Dan Case's Avatar
Default American Racing Wheels & Cobras
You will find two versions in various widths in period articles and advertisements.
1) Hidden Lugs: There are five large bolts that bolt into the back of flanges in line with the spokes. I have talked with people that have had problems with the bolt holes wallowing out.
Well used Hidden Lugs Wheel
2) Exposed Lugs: There are five large bolts passing through the center hub between the spokes and fixed with washers and American Racing acorn style chrome plated lug nuts.
Here's images of a NOS 6X15 Exposed Lugs Wheel
Unlike conversion to six pin drive magnesium Halibrand wheels these American made wheels required zero modifications to the street car hubs, brakes, or steering arms.
Even though the 6X15 wheel shown is magnesium, the entire assembly is pretty heavy because the walls are thick in cross-section and they have all the steel parts bolted to them. On bathroom scales the 6X15 wheel shown is just barely lighter than the OE 6X15 Dunlop made wire wheel it replaces.
Dan Case
Old 04-07-2009, 04:17 PM
LMH's Avatar
LMH LMH is offline
Dan
Is that adapter still available?
Old 04-07-2009, 06:05 PM
http://www.britishv8.org/Articles/Da...ire-Wheels.htm
Old 04-08-2009, 12:50 PM
Dan Case's Avatar
Dan
The American Racing ones are not but Phil Schmidt (spelling?) uses a very similar design (inside only as his wheels use a Halibrand style KO) for the aluminum wheels he makes for Cobras.
I located a 1966 American Racing catalog and it has a section just for Rudge-Whitworth splined sport car wheels. I have seen one Cobra with Ansen Sprint kidney bean slotted aluminum wheels using spline drive but I don't know if Ansen made the adpater et al. or an owner of the car did at some point.
Dan Case
Old 04-08-2009, 01:13 PM
A-Snake's Avatar
Originally Posted by mr bruce View Post
Mr. Bruce,
That's a different concept. The Dayton hub is to convert from bolt-on wheels to a knock-off wheel.
The 'adaptor' on the American mags or the PSE wheels is to be able to use alloy or aluminum wheels on Rudge-Whitworth splined hubs.
Old 04-08-2009, 01:14 PM
rokndad's Avatar
Cobra Make, Engine: CSX 4758, CSX 381 Keith Craft 482 w/ Weber 48 IDA's
Hello
Regards
ALF
I've seen and inspected the car and spoke to the owner. It is CSX 2075.
Old 04-08-2009, 01:23 PM
correct, only example of a Rudge adapter I could find, next time 2575 is in for service we'll get some pictures of the Rudge adapters
Old 01-20-2010, 02:10 PM
Default Yes it is
As the son of the former Owner it was indeed CSX 2075. My father sold it to its current owner after having it for 30 years.
I must agree it is a Mk I as it had leaf spring suspension..... as far as I know..??.
and yes it was a private Dragon snake and they were spline type wheels
Old 02-20-2018, 02:02 AM
TOSH's Avatar
Hello everybody,
I am the new proud owner of Gary Kadrmas CSX 2075 trying to collect more of 2075's history especially the long term ownership of Gary Kadrmas and the first ownership of Chet McFallo.
I would appreciate it so much if anybody on the forum can help me with my search.
Thanks a lot in advance.
bwcobra15, peterpjb and Alfa02 like this.
Old 02-20-2018, 12:48 PM
bwcobra15's Avatar
Cobra Make, Engine: Hurricane 427 Cobra #HM2008, Craft Performance 427w 600hp/600tq, TKO-600 close ratio, original Smiths gauges, lucas switches
Send a message via Yahoo to bwcobra15 Send a message via Skype™ to bwcobra15
https://www.youtube.com/watch?v=svkxRIhoAgk
Congratulations on your acquisition of this fine looking cobra!
So will it be going to Germany?!
Bob Worley
Hurricane HM-2008 build is done!! (for now....)
Craft Perfomance 427W / 600hp / 600tq - TKO600
I love it and I need it I bleed it ~ Yeah it's a wild hurricane ~ Alright, hold tight, I'm a highway star!!
Old 02-20-2018, 12:58 PM
LMH's Avatar
LMH LMH is offline
TOSH, do you have a current copy of the registry?
Alba gu brąth
Old 02-20-2018, 05:48 PM
xb-60's Avatar
TOSH,
Coincidentally, I asked some questions just recently about the unusual switches and levers in 2075. You probably know all about them anyway....
Gearshift 'mods' on CSX2075 - what are they?
Glen
Old 02-20-2018, 10:14 PM
TOSH's Avatar
@Bob
Thanks and yes, it will get a good new home among a few other nice American and German cars
Old 02-20-2018, 10:17 PM
TOSH's Avatar
Larry,
what year is the 'current registry' from? I have one and I think it is from 2008.......
