Go Back   Club Cobra > For Sale > Parts Wanted
Old 03-16-2005, 09:43 AM
R U YELLA's Avatar
Ed Digges
Cobra Make, Engine: Kirkham #328 w/ 390FE
Default Fuel Log for a Holley Double Pumper
Where do I get an original style fuel log that uses the rubber hoses from the log to the carb? I already have the AN style but it gets in the way of the turkey pan. Also needs to be able to have a fuel pressure line hooked up on the rear of it.
Old 03-16-2005, 09:54 AM
Hotfingrs's Avatar
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
Do you have the aluminum stand offs from the log to the carb...is so use some aeroquip blue hose, with push in fittings, for the lines and you should be able to clear the pan.
Jack
XSSIVE .....
Old 03-16-2005, 10:05 AM
R U YELLA's Avatar
Ed Digges
There is nothing to push the fuel log away from the carb! Believe me, I have checked & checked and then checked some more! This is the log that I use now:
Old 03-16-2005, 10:09 AM
Hotfingrs's Avatar
Replace your stand offs....from the carb to the log, with blue aeroquip hose and you can move the log just about any place you want.
Jack
XSSIVE .....
Old 03-16-2005, 10:16 AM
R U YELLA's Avatar
Ed Digges
No can do. It is a one piece setup. I want to go with the original style.
Thanks
Ed
Old 03-16-2005, 10:22 AM
chuckbrandt's Avatar
Club Cobra Member
Cobra Make, Engine: ERA # 665, 390 (to start with) Toploader
Default I got mine from the Kirkhams
I got mine from the kirkhams on ebay. You might give them a call. Real nice quality.
Chuck
Build website at www.chuckbrandt.com
Old 03-16-2005, 12:41 PM
Rick Parker's Avatar
If you have access to the right tools they aren't to difficult to fabricate. This design doesn't transmit as much heat into the fuel because it is not attached to the bolts that attach to the cylinder head. I also have it wrapped with insulation.
Picture is a little blurry........sorry
Rick
Rick
Old 03-16-2005, 12:49 PM
CSX 4027's Avatar
Cobra Make, Engine: Sold 3047 & 3002 in 2012
Default Fuel Log
The original design looks the best of course but, it has its problems. Because the 2 legs are attached to the intake manifold, you end up transferring heat to the fuel. You have to use an isolator washer before attaching or you could be boiling fuel to the carb. Not a good thing.
Steve Sunshine
www.competitionlife.com
"Hurry Up And Live"
Old 03-21-2005, 06:22 AM
DougD's Avatar
Cobra Make, Engine: Sold my beloved Shelby CSX 4068, Gessford 427 Ford
I just bought one from Motorsports International in California. Not cheap, but I believe it's exactly what you're looking for. Here's their phone # (619) 390-9080.
Doug
CSX4068, '69 Bronco, '70 BOSS 302, '87 Mustang GT, '08 Roush Trak Pak
Old 04-27-2005, 06:35 AM
R U YELLA's Avatar
Ed Digges
Rick - Can I buy yours or can you make one up for me?
Doug - Do you have a pick that you can post?
Thanks
Ed
Old 04-28-2005, 06:48 AM
DougD's Avatar
Ed
I'll take a pic tonite and post it.
The one I bought is steel, gold cad plated. It has the 45 degree brass fitting at the front to connect to the stock fuel line, and is threaded at the rear for a fuel pressure connection. Supposed to be exact as per the originals.
Doug
Old 04-28-2005, 04:25 PM
DougD's Avatar
Ed
Here's the pic:
Old 07-18-2005, 06:54 AM
R U YELLA's Avatar
Ed Digges
I found a fuel log by TC Race Cars out of Frostburg MD 800-296-3760 . Very nice looking log they make. It was $60 bucks to my door step. I removed the annodizing on the AN fittings but here is a pic. You can also find it under eBay by doing a search for "Fuel log" but here is the current listing:http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Thanks
Ed
Display Modes
HTML code is On
