21Likes
12-07-2011, 06:14 AM
The mass of the 15 gal fuel cell (filled) is too small to impact the drive ability. The original 427 with the large 42 gal (about 280 pounds) tanks over the rear axle had some problems with the slush. But nowadays this can be cured with baffles and sponges...
DRB GT40 MK1 red #49- sold
SPF 2063
12-07-2011, 11:18 PM
Looking really good  !
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
12-08-2011, 06:16 AM
Pete, your parts went in the mail yesterday 12/7
Roger
SAAC member and supporter
Club Cranky charter member
12-12-2011, 09:02 AM
Thanks Roger, got them on Saturday.
SPF 2063
12-12-2011, 09:34 AM
UK
Cobra Make, Engine: Dreaming of a 427 Competition car...
I love this build! I shall be following it from this point forward.
AWESOME! Inspirational, actually!
Paul
1966 Singer Chamois (Hillman Imp) - full race 930cc
1975 Triumph Stag - 3.0-litre
2003 Vauxhall Vectra GSi 3.2 V6
12-15-2011, 07:35 AM
Trunk and hood hinge fabrication.
Ready for welding.
First part done , the rods are 0.375 inch.
Attached to the cross front hood crossbar.
Same on the PA side. The full length rod is just for positioning, it will be cut later on.
Same method on the trunk.
SPF 2063
12-15-2011, 07:42 AM
Finishing the roll bar. Finalize the forward bracing.
The roll bar is 1.5 inches OD and has a wall of 0.125 inch DOM. The insert is 1.25 inch, pipe is drilled and insert welded.
Nice snug fit.
Floor attachment plate.
Top attachment and the whole bar.
SPF 2063
12-15-2011, 07:50 AM
Le Mans fuel cap positioning and mounting.
Base plate for the fuel cap.
Hole cut and plate in place.
The fuel cap sits horizontal in both axis. The plate simulates the top of the tank. The original tank was taller and wider and the fuel cap was directly attached.
SPF 2063
12-15-2011, 07:58 AM
Continues work on the trunk.
Framing for the spare tire. The finish drop (4.5 inch) will be fiber glassed.
Next on the to do list (not in a particular order):
Attachment of trunk and hood.
Fabricating door hinges.
Battery box design (in trunk).
Quick jacks front and rear.
...that's plenty for now.
SPF 2063
12-15-2011, 08:39 AM
tx
Dang Pete, you are rocking along!
Nice work on the hinges and the LeMans cap. Looks good.
12-31-2011, 05:03 PM
Tomorrow I post more pictures....
Happy New Year!!
SPF 2063
01-09-2012, 06:07 AM
SPF 2063
01-09-2012, 06:13 AM
SPF 2063
01-09-2012, 06:18 AM
SPF 2063
01-09-2012, 06:26 AM
SPF 2063
01-09-2012, 07:44 AM
Great work as usual, Pete.
What material are you using to glass the tubing with the CF? Vinylester?
- Allen.
01-09-2012, 08:12 AM
Evercoat 6oz fiberglass and West System epoxy resin - I have good experience with them bonding different materials and holding up.
I have a question for you Allen, how large are your auxiliary lights in front of your 289 and how many watts have they?
SPF 2063
01-09-2012, 10:30 AM
Pete:
Here is some info on the Driving Lights:
Adding Driving Lamps to your FIA/USRRC – “How To”.
They are Cibie Oscar lamps and I'm not sure of the specific wattage...I'll need to check for you.
- Allen.
01-10-2012, 01:42 PM
Allen, you're 100% right Jackson is a nice guy. I just ordered the lights, lets see if I can design a quick jack with the light bracket incorporated.
Thank you - very nice writeup btw...
SPF 2063
01-11-2012, 08:53 AM
Thanks, Pete.
That's cool! Both you and Jay (Crashburn) have contacted Jackson for lights form my thread write-up. Awesome! Looking forward to seeing how they turn out. I'm sure you'll do a great job with the quick-jacks. Biggest decision now is will you mount the quick jacks as outies or innies..
- Allen.
