Old 02-11-2011, 04:01 AM
Dominik's Avatar
Default Daytona body on 427 chassis
Good day!
I am halfway through the original style 427 chassis, will tackle suspension soon and wonder if a Daytona body would fit over a FE engine and if it has a 90" wheelbase?
Who has a Daytona body? Fibre is fine, I can't afford aluminium.
Dom
Old 02-11-2011, 06:16 AM
I make Daytona coupe bodies, I have a frame settup for an FE 427 and the carb and air cleaner fit under the hood with no problems, I'll try to find you a link to some pictures
Old 02-11-2011, 06:18 AM
http://rides.webshots.com/album/549738472iielQU?start=0
Old 02-11-2011, 11:38 PM
Dominik's Avatar
Default 90"?
Thanks, what is the wheelbase?
Old 02-12-2011, 04:12 AM
90" wheelbase
Old 02-12-2011, 11:25 AM
Jac Mac's Avatar
If your going to do an FE version, consider adding 3" to the wheelbase/frame, add 3" to the rear of front clip & front of sill's, plus a larger carb cover/scoop....
Jac Mac
Old 02-12-2011, 03:26 PM
I also have the 93" wheelbase body, and the FE fits under the hood no problem
Old 02-13-2011, 04:41 AM
Dominik's Avatar
The chassis is now 90", seems I thought a bit late about the Daytona shape?
Let me do a bit more research... And consider a longer chassis for the next project.
How much is the one to fit the 90" chassis? Is it doable, I am reading "add 3in" front and rear?
Old 02-13-2011, 10:02 AM
I have 2 coupe bodys, a 90" wheelbase and the 93" wheelbase, they are similar, but different, the extra 3" on the longer one wasn't just stuck in, the cockpit is a little larger, the flip front end is a little longer. Everthing was done proportional , there are pictures floating around the forum of the 93' wheelbase body, but I can't locate them, you'll have to dig around a bit.
Old 02-13-2011, 09:39 PM
Dominik's Avatar
Talking
Ok, let me get more parts from the drivetrain, position all (also suspension) and I will pm you how I intend to proceed. That will take a while. Those parts are not widely available in South Africa.
Maybe I come across a Fiat 8V Supersonic body to copy the Willment Ghia Cobra? (Rather unlikely..)
Old 02-14-2011, 03:40 AM
i got an original style 427 frame in storage, give me a month or so to get some other work out of the way, and i'll drop a 90" wheelbase body on it so you can see how everything fits
Old 02-14-2011, 01:59 PM
Wizbamsc's Avatar
Cobra Make, Engine: KMP 201 427 SO Tunnelport
Default Daytona on a 427 Chassis
Mr. Bruce, I would definately be interested in the 90" wheelbase Daytona body on a 427 chassis. How close to origional shape/ dimension is the 90" body? Thanks Phil
Old 02-14-2011, 03:12 PM
how close?, check out the pictures in the link, you be the judge.
