Like Tree163Likes
Old 08-31-2012, 05:24 PM
cobrakiwi's Avatar
Default New Build
It has been a long road but starting to see some light at the end of the tunnel.
Cutting/welding cutting/welding and more cutting/welding.
I have enjoyed the scratch build process.
Old 08-31-2012, 08:25 PM
mickmate's Avatar
Nice, it's been too quiet over here. Looking good.
mickmate
http://www.actoncustom.com/
Old 09-01-2012, 06:08 AM
cobrakiwi's Avatar
Default front tower
Here are a few pictures of the front tower and shock mounts.
albanycobra likes this.
Old 09-01-2012, 07:52 AM
Cobra Make, Engine: scratch building
Talking New Build
Fun stuff...looking good...
Old 09-01-2012, 09:42 AM
cobrakiwi's Avatar
I see from your pic's you know all about this stuff, rear tower getting ready to mount the diff.
Old 09-01-2012, 02:11 PM
What drawings are you using for measurements? The Cobra Restorer's drawings?
Is there a set of "corrected" drawings available that address the mistakes on the Cobra Restorer's drawings?
Great looking work. Keep the updates coming.
Old 09-01-2012, 03:33 PM
cobrakiwi's Avatar
Hey Bob
I have made all my own patterns, I have some old drawings I have compared measurements too. The next frames should take a lot less time now.
How is your project coming along?
Here is a few pictures of the diff being mounted, rear shock mounts and brackets.
Old 09-01-2012, 06:46 PM
mickmate's Avatar
I like the old school seat belt tabs.
mickmate
Old 09-02-2012, 07:55 AM
cobrakiwi's Avatar
Next was starting the cowl hoop, out riggers, floor brackets, and steering rack mounts.
prp289 likes this.
Old 09-02-2012, 08:24 AM
LMH's Avatar
LMH LMH is offline
Wow, very nice!
Alba gu bràth
Old 09-02-2012, 08:53 AM
cobrakiwi's Avatar
Default Brakes
Larry, Thanks.
They say with all that GO you need to stop so here is the brake control department.
Old 09-02-2012, 11:16 AM
cobrakiwi's Avatar
Default setting the engine and gear box
Here I have made up the engine and gearbox mounts.
Setting the engine and gearbox up before more frame work makes it an easy task.
alfy65 likes this.
Old 09-03-2012, 07:38 AM
cobrakiwi's Avatar
Default cooling
Now that we have an engine and brakes we will need some thing to cool that big lump of iron up front, Radiator mounts for the radiator. As well we may need help going around corners so sway bar mounts need to be fitted. The oil cooler brackets are all so fitted, they all so support the lower front body. The mounts for the Quick jacks or bumpers get tied into the front frame as well.
This was quite tricky to set up and get right.
Old 09-05-2012, 10:26 PM
Send a message via AIM to krausewich
Hi Kiwi,
Things are looking awesome over there! Can't wait for more updates.
From a scratch builders POV, may I recommend tacking a few pieces
of your birdcage together and get the body on there to test fit. Those
drawings and bodies rarely seem to agree : )
Good luck and continued success.
Mike.
-J. James
M. Krause
1.508.944.3368
Old 09-06-2012, 12:02 PM
cobrakiwi's Avatar
Default More Brackets
Hi Mike,
thanks, yes I would agree with building the body frame work around the body and the body sitting in place.
Here are a few more Brackets that we need to build and place on the frame.
Bracket for the rad cooling fans, side pipe mounts, steering column, wind shield and drive shaft loop mounts.
Old 09-06-2012, 01:40 PM
cobrakiwi's Avatar
Default body frame
Here we are starting to build the frame work to mount the body too.
The door hinge mount is all so tied into the frame work for the body.
Sorry for the clutter in the back ground with some of these pictures.
I think this is what Mike was referring too with making the frame work fit the body.
Some of these rolled tubes and bends are tricky to get right.
Old 09-10-2012, 06:12 AM
cobrakiwi's Avatar
Default rear frame
now we are putting together the frame work for the rear body to hang on, all so all the frame work for the trunk, rear panels, and rear bumpers or quick jack mounts.
Old 09-10-2012, 12:16 PM
cobrakiwi's Avatar
Default doors
we need doors, so here we are making the hinges, latches, catch plates etc
Old 09-10-2012, 12:20 PM
cobrakiwi's Avatar
Default mounting doors
Mounting the doors,
Old 09-10-2012, 12:24 PM
cobrakiwi's Avatar
Default test fitting
Now we test fitted the body, looks like it might just work.
Ram427 likes this.
