Old 05-22-2013, 06:44 PM
Post Hydraulic Or Mechanical
Is it worth the expense and effort to use a hydraulic clutch? Does it reduce pedal effort?
Old 05-22-2013, 06:58 PM
Had both. Cable broke, leaving me stranded.
Now I have hydraulic.
Old 05-22-2013, 07:02 PM
mickmate's Avatar
Hydraulic with the leverage of a fork makes an easy clutch pedal.
mickmate
http://www.actoncustom.com/
Old 05-22-2013, 08:22 PM
PNJSNAK's Avatar
Cobra Make, Engine: A&C 427S/C, 351W, T5
Never going back to cable, to hard to push and it broke leaving me and the boss stranded, not happy!
Spent the money and converted over to hydraulic, Sweeeeet! Works like a dream, very little effort to push the pedal.
Why I didn't go this way in the first place.
Didn't know about this forum and listened to others, bad advice.
Now the question for you is a fork design or on the trans shaft like a Mcleod (sp?).
I went with a fork design and am very happy.
OhioCobraClub.com
Old 06-12-2013, 10:39 AM
map's Avatar
map map is offline
Cobra Make, Engine: Myself/Body from CSX-2575 & hand built Birdcage
Send a message via Skype™ to map
Hydraulic hose broke on CSX-2268 at Pocono (SAAC-10) I drove back to Great Gorge NJ without a clutch..
6S1941
Allied 289 Slab Side
73 2.3 turbo pinto
Old 06-12-2013, 11:42 AM
GT350Mike's Avatar
Cobra Make, Engine: CSX6363
No comparison.......a hydraulic clutch is the only way to go.
Old 06-12-2013, 05:14 PM
mickmate's Avatar
Diaphragm type pressure plates are also easier to operate than long style or spring and lever type. The type with centrifugal weights for holding give better clamping at higher RPM. I'm using that with external hydraulic in mine.
mickmate
