1Likes
Post By cycleguy55
12-13-2018, 02:56 PM
No subject context, and from an unregistered user? (Wigly)
12-15-2018, 06:10 AM
I am a registred user but don't know why my main thread is gone..
12-16-2018, 09:31 AM
TR
Cobra Make, Engine: scratch built 289 eclectic mix of fia/ussrc/early comp
Hi Wigly,
You need much more of information than only "cobra restorer blueprints"
Because of missing or wrong dimensions !
https://www.ozgurtan.com/2018/10/ori...hassis-3d.html
12-17-2018, 03:57 AM
Hi Wigly,
Is this your previous thread, and you can't access it:
Thickness main tubes of org. 427 Frame
Have you lost your log-in, or having difficulty logging in?
You haven't posted for a while, so maybe your login is lost in a site database update?
12-17-2018, 10:16 AM
Hi everybody,
i put every information in here, but after the linking to my galary my main artikel disappears. I've saw a message that an admin has to check my post...
I am working on the last details of my CAD CR-Chassis model and need some help.
Can somebody tell me the correct angle of the shock tower and backcut angle of front lower A-Arm bracket?
12-17-2018, 10:21 AM
Neutral
@Gary
I can login and everything, the only problem seems to be in the image linking.
The Thickness main tube thread is an old one.
12-17-2018, 10:51 AM
TR
required angle of the shock tower: 109deg
required bracket dimensions: 35.10mm and 72.48deg
Hi everybody,
12-17-2018, 02:17 PM
Hi everybody,
@Gary
The reasons are since you are a fairly new low post user, the admins have to authorise file attachments etc.
Once you are past a low of figure of 10, it becomes a lot easier.
The reason they do that is they have to learn to trust new members to limit spammers.
12-17-2018, 02:20 PM
SK
An alternative may be to have the images hosted elsewhere and provide links to them in your post / comments.
Brian
12-18-2018, 10:30 AM
@Gary
thx for that information.
@Brian
I did that but it just didn't work
But nevertheless.. you can see the images in my galary right?
@Ozgur_Tan
the bracket dimensions sounds a little bit odd to me. Converting the 35.1 mm in inches isn't the size i would expecting
How long is the main tube without the end cap? -> in the blueprint (first page) it looks like the total length includes the end caps..
12-18-2018, 11:15 AM
TR
g'day
it was long time ago, they are OK but i'll post more when i return to home.
i also have to work with imperial then convert to metric dimension values.
as you may see attached my WIP screen shots
suspension pickup points at chassis side etc. are correct
i'm still working on some details
peace
ozgur
ozgurtan.com
01-19-2019, 09:11 AM
Hello everybody, it's me Wigly. I have had to create a new account because the old one wasn't working anymore -> even Brent Mills reseted my pw... i couldn't login.
@Ozgur_Tan
Thank you for the information.
if i check the position information of the upper support tube the end caps are 0.125 thick and not 0.120. Is that right?
01-20-2019, 10:49 AM
UK
Cobra Make, Engine: DB427SC. 289FIA. COUPE. Round tube, Aluminium body, 427FE
It all depends which drawings you are looking at.
I have some with and without the caps both saying 96.75"
02-17-2019, 09:31 PM
MA
Hi Wigly! Welcome back to the build section... For the Endcaps and other 1/8" steel bracketry, you should use .120 for your measure as 11ga steel sheet will not be .125 Go with the 96.75 Overall and start your build from the rear forward ; )
Good luck,
-J. James
M. Krause
1.508.944.3368
04-27-2020, 11:05 PM
Hi everybody,
after a very long time i can login again. YEAH
Thank you so far for the information.
I am currently working on the front upper and lower control arms, guess will need some help later on.
10-31-2021, 12:58 AM
Hi Again,
can somebody tell me the correct length of the rear tower top side tube?
thx
10-31-2021, 10:52 PM
TR
225 mm
center to center, aligned
ozgurtan.com
Hi Again,
thx
11-01-2021, 12:49 AM
Originally Posted by Ozgur_Tan
225 mm
ozgurtan.com
the center to center length is fine for me but i am still not sure about the total length of the tube. Based on the CR prints or my guessing it is to short
11-01-2021, 01:14 AM
TR
extension from center is 22mm
11-01-2021, 02:21 AM
so the total length is 9.75", or should be if the tube dia is 1.75"
