Like Tree10Likes
  • 4 Post By
  • 1 Post By
  • 2 Post By
  • 2 Post By Ozgur_Tan
  • 1 Post By Ozgur_Tan
Old 12-20-2023, 03:05 AM
Ozgur_Tan's Avatar
Cobra Make, Engine: scratch built 289 eclectic mix of fia/ussrc/early comp
Tommy and 1985 CCX like this.
Old 12-26-2023, 01:17 AM
Dominik's Avatar
Your CSX 4000 front upper control arm look alright, but camber the adjuster appears too long.
Which would mean your LCA is also too long, or you have way too little KPI on the front upright.
What is your hub to hub measurement? I.e. from wheel mount surface to wheel mount.
Once back in the shop I may be able to find the total length of the UCA (CSX 3000) somewhere (240 mm?).
Lower sees 270 mm.
If I don't respond anymore, that's because I can't log in
Old 01-22-2024, 10:40 AM
Ozgur_Tan's Avatar
1985 CCX likes this.
Old 01-23-2024, 12:14 AM
Ozgur_Tan's Avatar
G'day Dom,
Kingpin: 11.4 deg
Camber: -2 deg
Caster: 3.5 deg
Lower Control Arm: 277.5 mm
Upper Control Arm: 210.7 mm
hub to hub: 1,322.4 mm
Lower sees 270 mm.
