Old 01-23-2026, 10:46 AM
2020 GT500 CFTP's Avatar
Cobra Make, Engine: Hi-Tech 428 six pack
Default Small block frame
Hello all, I picked a sb frame and parts. CSX7000 series foot boxes, dash, Shelby gauges fuel cell/tank, cap. I'm in no rush but would like to assemble a comp car out of it. I'll need to start maybe with the bird cage dimensions. any schematics out there?
Old 01-24-2026, 02:13 PM
Cobra Make, Engine: MidStates, 351C, 4spd, 9"
Send a message via AIM to krausewich
Best advice for that build would be to position the body you are going to use and build the cage to it. Every body is a bit different. Some positioning numbers would help you along
"It's not about getting from point A to point B. It is the point"
-J. James
M. Krause
1.508.944.3368
Old 01-25-2026, 08:36 PM
Thanks for that. I must first find or make a body.
Old 01-26-2026, 06:19 AM
old willy's Avatar
Cobra Make, Engine: Mine, small block FORD
Hi there,
By comp car I am guessing you mean the fia or USRRC version. As far as I am aware the difference is just in the shape of the door opening, they just added a piece of tubing to reverse the curve of the door for more fender room. Plus the single roll bar and its mountings. I would suggest you buy a set of Chuck Lindquest’s (chuckcobra) drawings.
The first set covers the complete basic chassis including the door, hood and trunk frames. The second set covers suspension parts and most of the interior and inner fender panels and the roll bar parts.
I do however agree with Krausewich that you need figure out the body first. Chuck’s drawings also state that you may need to modify tubes to fit your existing body, I know I did. That is unless you wish to build the frame work and then fit an aluminum body to in the manner AC Cars did it.
My body is fibreglass of an undetermined origins so I am doing a bit of both, fitting to it and using Chuck’s drawings to rework some of the body to be somewhat more correct.
Just my 2 cents worth
Hudson
Yes, I know,....... but it's mine you see.....
Perhaps he was always a shyster, but we just chose to over look it for awhile.
You build what you like and I will build what I like...it's all good
You know that guy,
The one in the neighborhood who likes to hang around the garage while you are working and talk about back when he had that killer 1977 Chevy Mustang
Old 01-26-2026, 01:13 PM
twobjshelbys's Avatar
I hate to do it but I'm the Forum Debbie Downer on these kinds of projects.
Are you an experienced machinist and builder? You're going to need lots of tools, a good number of which you will only use once, and a lift will prove most beneficial. Be sure to factor this into your cost.
If you aren't, then I'd suggest that there are lots of easier and much less frustrating scratch build projects that would get your feet wet. The cobra has no straight lines and that is a big obstacle to those not experienced with metalforming.
Keep us posted on your progress and your requests for the pieces you are missing as some of the people are packrats and may have some of the missing parts. You have somewhere around 15% of what you need to build a Cobra. There's lots of blanks to fill in.
Be careful though. By the time you acquire many of these parts and invest the time in assembling those things you need to manufacture, the money spent would be the same or more than just buying a finished Cobra. if you're in it to bust knuckles and the cobra is a side effect then by all means go for it but understand this is a non-trivial project that will probably take you a couple of years.
Note also, since you're new to this forum, that most of the advertisers on this forum no longer exist... There is a lot of attrition in the Cobra space...
If you can overcome all of these supply and experience issues then please keep us posted on your progress! Good luck!
Note also that this forum is gone more than not so connecting with the knowledge base is becoming more and more difficult. There is another place that might; try talkcobra.com
Tony
CSX4005LA
Old 02-11-2026, 05:16 PM
Cobra Make, Engine: era#671 Keith Craft Motor
By looking at 2020 GT500 Photo gallery i don't think he will have any issues at all assembling the car....Have you looked at his accomplishments?
