Like Tree3Likes
  #61 (permalink)
Old 01-11-2012, 09:07 AM
Send a message via AIM to krausewich
Hi Mark.
Let me check my email for your address and I'll get'em over to ya.
Glad I can return the favor!!
Mike.
-J. James
M. Krause
1.508.944.3368
  #62 (permalink)
Old 01-11-2012, 09:12 AM
Cobra Make, Engine: 289 Leaf Spring - On Hold
Mike,
My email address has changed from the one you have more than likely.
I did update it on CC.
It is now mwloy at comcast dot net
Thank-you!
--Mark
  #63 (permalink)
Old 01-11-2012, 09:37 AM
Good to go !
MK.
-J. James
M. Krause
1.508.944.3368
  #64 (permalink)
Old 01-12-2012, 10:43 AM
Thank-you my friend!!!
--Mark
  #65 (permalink)
Old 01-17-2012, 09:46 AM
G-Pete's Avatar
PM sent
thx
DRB GT40 MK1 red #49- sold
SPF 2063
  #66 (permalink)
Old 01-17-2012, 09:35 PM
Dominik's Avatar
Ah, a reanimated thread ;-)
427sharpe
"I wanted to ask him why the 427 used a welded on rear subframe as opposed to a full length frame rail"
I see three reasons: it could be a sacrificial crash box, the LCA needed more length than the extended main rails would allow for (most likely reason), or simply the designer had one length of tubing in mind per car (6meters, 18ft)
Yes, the rear suspension steers in roll (cornering) and changes toe in bump/droop.
I believe Morris designed that out of his car, relying entirely on new generation slicks for traction (and thus eliminating the tendency of the suspension to bind).
If I ever build another chassis, I would change the rear to look like a 289 suspension or SPF.
  #67 (permalink)
Old 01-18-2012, 06:58 AM
Hi Dominik,
I'd firmly support option #2. Even with the standard 22-24'
length's of tubing, there would be enough material to go all
the way back. That's the way Alfy65 did his frame. Looks
awesome too!
Mike.
-J. James
M. Krause
1.508.944.3368
  #68 (permalink)
Old 01-18-2012, 07:02 AM
mickmate's Avatar
You guys know the deal already if the 4" tube went all the way back it would be right in the way of the rear lower inner mount. They could have done some clever hot rod smoothing with a recess that housed it in the tubes but they were keeping it simple.
mickmate
http://www.actoncustom.com/
  #69 (permalink)
Old 01-18-2012, 07:43 AM
Dominik's Avatar
Hi Nick!
They could have :-)
Mike,
don't forget to add the crossmembers.
Of course, AC never planned to build one chassis at the time, and I forgot how it adds up after notching the crossmembers.
I figure the crash-box and LCA length is the reason.
  #70 (permalink)
Old 02-12-2019, 02:09 PM
Hi!
I see this is an old thread, but any chance the 289 plans are still available and can be shared? Would be very much appreciated!
Best regards Peter
  #71 (permalink)
Old 02-13-2019, 11:57 AM
cycleguy55's Avatar
Try emailing Mark at mwloy at comcast dot net
Don't forget to let us know what you find out!
Brian
  #72 (permalink)
Old 02-25-2019, 03:12 AM
Thanks! Got a reply from Mark
Regards Peter
cycleguy55 likes this.
  #73 (permalink)
Old 04-09-2019, 12:59 AM
Hi!
I generously got a partial set of drawings from Mark and then he would find the remaining part from an old computer. However, now it seems as my mails are not getting through, or at least no response. Anyone who have drawings and is willing to share one way or the other?
Regards Peter
  #74 (permalink)
Old 04-12-2019, 04:43 AM
Ozgur_Tan's Avatar
Cobra Make, Engine: scratch built 289 eclectic mix of fia/ussrc/early comp
g'day
i thought that it would better to upload google drive or dropbox for sharing
regards
ozgur
