Old 03-06-2009, 06:43 PM
Cobra Make, Engine: scratch building
Talking Dual master cylinders
Found some good info basics:
http://www.stoptech.com/tech_info/Pe...ster-Guide.pdf
Old 03-06-2009, 07:09 PM
mickmate's Avatar
Nice Alfy, there are a couple of Excel spreadsheets out there too and I also made one up where you can just put your values in and it will give you the front rear balance. I based mine on Paved Track Stock Car calculations that disagrees somewhat with his theory of giving it a little too much rear and then choking it off to suit. They recommend balancing as closely as you can with the hydraulics and liked to see I think 66% on the front.
mickmate
http://www.actoncustom.com/
Old 03-06-2009, 07:46 PM
Talking Dual masters
Mick,
I agree , I am setting my bore size to the pedal ratio which is about 5.5 to 1.Then I should be able to fine tune with the balance bar.I will have the gauges in dash to watch pressure value between front and rear.Sounds good in theory at least...
