Old 07-30-2006, 06:55 PM
elgecko's Avatar
Cobra Make, Engine: Scratch build......a little every day.
Default Pedal Box
Are there any drawings, measurements, or ???? out there for the original pedal box. Time to start fabing one.
dave
55 mph is unsafe at any speed. Huh?
Old 07-30-2006, 07:01 PM
mickmate's Avatar
Hi Dave, I'll send you an e-mail. Let me know if you find out any more.
Cheers Nick
mickmate
http://www.actoncustom.com/
Old 07-30-2006, 08:26 PM
Cobra Make, Engine: Starting a Scratch Build - 289 FIA Car
Default pedal box
I can make a drawing up off of my frame if you like. I have an original style 427 frame from the Hi Tech jig (Tim Gunning).
Scott
Old 07-31-2006, 07:11 AM
mickmate's Avatar
I like, I like. That would be great, I have the front master layout if you want me to send that to you.
mickmate
Old 07-31-2006, 07:24 AM
NOSMS's Avatar
I have at least one of everything out of a pedal box if you still need help let me know. You can email me directly @ mknos@att.net or call @ 602-400-7725.
Old 07-31-2006, 05:46 PM
elgecko's Avatar
The pedal box will have to be modified (i think) because I am just using a brake pedal with two Wilwood cylinders (hipo manual shift C4). Trying to get (build) a stock looking box.
Dave
Old 07-31-2006, 10:17 PM
No problem making a drawing of the box..... I have a pdf prepared already that has the front layout for the thru tube and brake and clutch cylinders. Is this what you are looking for or?
Scott
Old 08-01-2006, 03:20 AM
mickmate's Avatar
That's what we're after. It would be great if you could put it in your gallery or e-mail it to Dave or myself.
mickmate
Old 08-01-2006, 03:39 AM
elgecko's Avatar
Hi Scott,
One fellow member sent me a front panel layout( inside front view).
Pretty nice. But I am wondering if there is a SIDE view layout showing length?
Thanks for your time.
Dave
Old 08-01-2006, 06:46 PM
mickmate's Avatar
Dave, get your e-mail cleaned up I'm trying to send you some good pictures!
mickmate
Old 08-01-2006, 07:19 PM
elgecko's Avatar
Sorry Nick,
Best to send larges files to my wife's email at l_retta@yahoo.com
Dave
Old 08-02-2006, 12:46 AM
Dominik's Avatar
hi guys,
I someone would just quickly install a PC partiion on my mac, I could identify the relevant drawiing and send it...
the positions for the master cylinders must be quite accurate that the guiding sleeve for the actuating rod also fits - if you use it...
if you really get desperate, I drive to get the hardcopies and fax them.
dominik
Old 08-02-2006, 09:33 AM
mickmate's Avatar
Hi Dom, we're scratch builders nothing happens quickly enough! Dave I'll resend tonight.
mickmate
Old 08-03-2006, 02:38 AM
Cobra Make, Engine: scratch building
Talking Pedal box
Ok guys, you have my interest...just post a drawing and lets see what ya got
Al
Old 08-03-2006, 05:40 AM
elgecko's Avatar
Default box
alfy65,
After months of consultation between us scratch builders we have come up this detailed drawing that should help. Please call for help anytime.
Just kidding.
One or two drawings that I have are copyrighted, so I'm not sure of the legality of putting these on the site.
Will PM you later.
Dave
elgecko
Old 08-03-2006, 09:21 AM
mickmate's Avatar
mickmate
Old 08-03-2006, 09:45 PM
Dominik's Avatar
Default pedal box
g'day!
there is a bit of progress: after some "scratching" I found the drawing.
but they are too big (A3) for the fax machine, so I either have to reduce them in the copy shop or cut them in pieces...
Or check my files on someones PC, because my new mac is not partitioned for PC yet.
domink
Old 08-07-2006, 08:57 PM
Default Pedal box
If you want to take the easy way out, Tim Gunning has a complete box (less the pedals and balance bar) for sale for $90. He also has the pedals, balance bar, push rods, etc for the box. You can reach Tim at:
bestof65@azci.net
Scott
Old 08-08-2006, 03:17 AM
elgecko's Avatar
Since when do scratch builders take the easy way out
I've used Tim before , probably will again.
Dave
Old 08-08-2006, 07:58 AM
The only area that they seem to take the easy way out is under the hood. A real scratch builder would probably want to cast his own block, forge the pistons, rods, and crankshaft... just kidding. The work that is done on this site is very professional, in many cases better than the orginal car!
