Like Tree4Likes
  #41 (permalink)
Old 12-02-2008, 12:05 PM
Juggernaut's Avatar
Cobra Make, Engine: RUCC, 289 c.i. with a T-5 "Living the Cobra Experience"
I'll put the word out around here Carl.
See ya,
Randy
Juggernaut
  #42 (permalink)
Old 12-02-2008, 08:00 PM
63mercury's Avatar
Cobra Make, Engine: Scratch building frame,FFR Mkll body ,302w, and T5 trans, 3.0 rear.
Hey guys, I was looking thru my new Ford performance catalog today and found out that I have 3 yokes already, the C-4/Aod and the T-5 use the same yoke. Thanks for your help Carl.
1963 Mercury Monterey 460+ .060 .//Cobra clone, Scratch build frame /302/ T-5 WC / 3.00-9in/FFR mkll body (Broken but repairable) /91 Lincoln Wire Wheels // : N.S.M.C Charter/Life Member// Die Hard Blue Oval Nut
The finish is better than the beginning. Ecc7:8
  #43 (permalink)
Old 12-02-2008, 08:58 PM
fasterpatrick's Avatar
Cobra Make, Engine: scratch build self design 4.6l DOHC
Carl, you wouldn't have one for a C-6 that will also fit my t-3650 I was looking though the same book. Otherwise its time to go junkyarding.
Patrick
http://www.clubcobra.com/photopost/s...0&ppuser=23754
Well, it occurs to me that perhaps not all of the modifications I made are technically 'street legal'
Nothing good ever happened after this statement;
Hey Moe watch this!
  #44 (permalink)
Old 12-03-2008, 06:14 AM
63mercury's Avatar
Patrick, I will check the stuff today and PM you what I find, Carl.
  #45 (permalink)
Old 01-19-2009, 04:24 AM
63mercury's Avatar
Well yesterday I finished the disassembly so I can get the finish welding done, lots of things going on so work has been slow, still picking up parts as I find them and can afford them, this is a pay-as-you-go project, just like most any other hot rod build. Got the engine mostly buttoned up, still looking for a passenger side header to use as a pattern if it's too bad to use, have two for the driver side, a 302 & a 351 FFR style. More later, Carl
  #46 (permalink)
Old 03-05-2009, 08:04 PM
63mercury's Avatar
Well got all the welding done unless I haveto add something else, engine,trans, and suspension are mounted. The trans mount needed modifying but thats no biggy. More pics in my gallery.
Carl.
  #47 (permalink)
Old 03-10-2009, 11:15 PM
Hey Carl, make sure you take lots of notes and prepare final drawings when you are done. Looks like the boys in THIS THREAD will be needing a frame and chassis design for their project.
Excellent work!
  #48 (permalink)
Old 03-11-2009, 06:20 PM
63mercury's Avatar
Thanks Jim, I'm updating my prints as I make changes and if anyone has a need when it's done I will make everything available. Right now I'm working on the cowl hoop, after I got the dimensions from you I found I was about 3 in too far back and too wide at the top. The outriggers are perfect so tomorrow the work continues.
  #49 (permalink)
Old 03-11-2009, 07:16 PM
Juggernaut's Avatar
Wow, looking good Carl! Man, you do good work.
How's everybody doing up there in the snow?
Tell your wife & brother the gang from IHOP says "Howdy!"
See ya,
Randy
Juggernaut
  #50 (permalink)
Old 03-12-2009, 04:37 AM
63mercury's Avatar
Thanks Randy, the snow is slowly fadeing away ,we're supposed to be in the mid 40's this week and next, right now it's 8. Tell the guys at Ihop we are hoping to be down this summer, the house project is about done then I start packing some of the shop stuff up.
  #51 (permalink)
Old 04-02-2009, 08:28 PM
63mercury's Avatar
I just posted some more pictures in my gallery, the dash hoop and steering is starting to shape up. Got the clutch slave cylinder mounted, will be starting on the pedal support this week. More to come. Carl
  #52 (permalink)
Old 05-11-2009, 07:01 PM
63mercury's Avatar
Just a short update, Got my gauges,(used VDO),quick jacks, all three master cylinders, the new dash is out to the plasma cutter to get the holes cut in per my deminsions, looking into building my own pedal support. More later, Carl
  #53 (permalink)
Old 05-12-2009, 05:48 PM
Juggernaut's Avatar
Glad to hear work is still progressing Carl! I was waiting for another update, been a little while since your last one.
Randy
Juggernaut
  #54 (permalink)
Old 05-16-2009, 05:30 PM
63mercury's Avatar
Hi Randy, I've been gathering parts, got the side pipes comming, now I MUST put the cash aside for the body. The move is progressing slowly, my sister is still trying to sell their place so they can buy ours. Also working on the 49 Ford pick up for the wife. Carl
  #55 (permalink)
Old 05-16-2009, 08:50 PM
Juggernaut's Avatar
Originally Posted by 63mercury View Post
Hi Randy, I've been gathering parts, got the side pipes comming, noe I MUST put the cash aside for the body. The move is progressing slowly, my sister is still trying to sell their place so they can buy ours. Also working on the 49 Ford pick up for the wife. Carl
Sounds like you've been a busy boy! Do you know where you're getting the body from? Not sure if Mickey can help you out, I just found out yesterday that he has colon cancer.
Glad to hear that the move is progressing even if it is slowly, thats better than no movement at all!
Post a picture of that 49, would like to see it.
Randy
Juggernaut
  #56 (permalink)
Old 05-24-2009, 06:41 PM
63mercury's Avatar
Another update, just posted 6 more pictures in the gallery, the remote filter is mounted and I used hydraulic hose instead of neoprene because if I ever blow a fan belt I won't lose the engine oil as well.
  #57 (permalink)
Old 05-24-2009, 06:47 PM
63mercury's Avatar
I will try again,
  #58 (permalink)
Old 05-24-2009, 08:17 PM
Jac Mac's Avatar
Hi Carl, Those 90° fittings for the remote filter are NOT a good idea, use radius or sweep bends/fittings where ever possible. Also have a good look at the hyd fittings & hose to ensure they are no smaller in the I.D. than the gallery dia of the cyl block ( Somewhere between 7/16"-1/2"). Its hard enough on the pump to get the lube around without us guys adding to the load. Great work, your making a lot more progress than me!!
Jac Mac
  #59 (permalink)
Old 06-28-2009, 05:42 PM
63mercury's Avatar
Another update, now have my pedal assembly(wilwood), unisteer rack, and sidepipes, and am making up cardboard templates for the trans tunnel, and footbox areas. I am thinking of putting a lifting system under the pass seat so the wife can get in and out easier.
  #60 (permalink)
Old 07-15-2009, 01:42 PM
63mercury's Avatar
Another update, steering is in, will have to fine tune it when body and seating is finished. Pedal assembly is in, master cylinders are mounted, next comes the plumbing of the front and finding the rear disc kit, I am leaning toward the one from Speedway Motors for $429, that looks pretty good.
pics will follow as soon as I get them into the gallery. Carl
