01-24-2008, 01:59 PM
OR
All Wheel Drive Cobra?
I know this is a question nobody is asking, and a solution without a problem, but did you ever think about building an all wheel drive Cobra and wonder what it would take to accomplish it?
Well, here is the answer to the toughest part- a drivetrain with front and rear differentials, motor, etc.... -
eBay Motors: 2007 Lamborghini Murcielago LP640 engine & drivetrain (item 320210792229 end time Feb-01-08 10:50:58 PST)
Whatcha' think? Who will be the first on their block (or planet) to put one of these puppies in a Cobra? Come on, don't be shy......
01-24-2008, 02:02 PM
The guys in UK did that using a Ford Sierra Cosworth driveline.
01-24-2008, 02:11 PM
NV
And with one gear forward and six in reverse, this all-wheel drive Cobra could go like hell backwards... ;-)
Ken
01-24-2008, 02:22 PM
OR
Minor detail, nothing a good scratch builder couldn't figure out......
01-24-2008, 02:29 PM
Beam Me Up Scottie
MA
I've thought of making a Cobra with ABS and traction control. Now that would be nice for getting off the line without blowing off the tires.
Warren
01-24-2008, 02:42 PM
NV
I always thought the concept GM used with the Typhoon/Syclone AWD would be workable in a Cobra (use the driveline from an existing setup and shoehorn it in)...it would require major surgury on the front framework, but would result in one VERY quick 0-60 time...not to mention some improvements in the quarter mile times. Interesting, but way beyond my level of ambition right now.
Didn't one of our Aussie friends do an AWD Cobra?
Ken
01-24-2008, 03:05 PM
mo
I have give this some thought ,the part i cant seem to figure is the transfer case now if went to the passenger side it could allways be a singal seater,my very limited AWD exp.has the transfer case on the drvers side that would cause you some pain to sit on while you try and drive. Lord know all four wheels pulling would be great for a very traction limited car anyone know of a case that would come out on the pass. side? Neat idea!!
01-24-2008, 04:17 PM
Cobra Make, Engine: Gulf GT40 CAV137, Cobra ERA286
You guys are nuts! If you want all wheel drive..... buy a Hummer!
Gulf GT40 CAV137
427 Cobra ERA286
01-24-2008, 04:25 PM
UT
Cobra Make, Engine: FFR4277 302 EFI
Do a google search on Quadradeuce to find a 32 Ford using AWD from a Typhoon. Very cool and quick.
01-24-2008, 04:40 PM
OR
After looking at this more, with the rear engine set up, this would be the perfect drivetrain for the Factory Five GTM to make it all wheel drive. Now if the asking price wasn't starting at $30 K it would be pretty interesting to give it a try......
01-24-2008, 05:04 PM
Yeah, I was going to say the same thing. The QuadraDeuce (circa 1995) was a very trick idea. It used the GMC Syclone AWD system, had a 500hp aluminum block V8, T56 six-speed tranny, and a ZR-1 rear axle.
0-60 in 3.2, 1/4 mile in 11.7
Your pal,
Meat.
02-22-2008, 11:14 AM
az
Cobra Make, Engine: none yet but it will be mostly scratch
The '70s and '80 full size jeeps W/fulltime 4wd had a TH400 trans W/BorgWarner chaindrive aluminum Xfercase. It has a Auborn style limited slip vacuume actuated locking center differential. This tranny/Xfer setup is cheap,strong and plentiful.It comes W/BPOC bellhouse pattern, but it would be easy to put the guts in a GM TH400 and have unlimited engine chouces as long as you wanted a Bowtie.
It hangs down on the passengers side.I think if one could "clock" it so it was next to the tranny instead of below, you could do this without loosing ground clearence. I would use the front suspension off of any IFS 4X4 mini truck. Maybe use it in the rear as well.
If you started with this drivetrain and built a cage frame around it, I think you could manage two passengers
No scratch all that...It will not work
the front diff on any IFS front end is mounted on the centerline of the vehicle. Even though with the setback of the engine, the front diff would be infront of the engine, the front driveshaft would have to go around the engine.
tim "FISH" fisher
Tucson,AZ & Kabul,Afaghanistan
02-22-2008, 12:09 PM
I came from the subaru AWD world and had a 700 hp awd STi. It was insane. I would love to have an awd cobra but i think it woudl be insanely hard to make happen.
02-22-2008, 12:23 PM
Cobra Make, Engine: Midstates,SBF 357
You set the engine in at an angle just like the HMMWV
02-22-2008, 01:38 PM
Guys,
Ram ,if I remember right, had a kit using the the Sierra 4wheel drive stuff, as mention above.
So yes you could take a Subaru or Mitshubishi drivetrain and make an all wheel drive car. It would be difficult, but not impossible... I don't know the implication of all the electronics. especially today with the diffs.
Now the Ram all wheel drive car although cool, lack one thing ... The V8, the bruteness of the beast. Face it we love cobras for what they are... Pure brute horsepower...You lose that with a 4 turbo allwheel drive set-up.
Fred
02-22-2008, 01:47 PM
This is a car that I actually have started to gather parts for. My new Aluminum backbone chassis uses C-5/C-6 suspension. The Hub carriers (spindles) are the same front and rear, so I can run all wheel drive with the stock Corvette suspension!!!! Am mocking up the Cyclone?typhoon stuff at this point. It will be fun!!!!!!!!!!
02-22-2008, 04:20 PM
That's it, increase the weight, put on stiffer springs, use truck parts and go faster.......NOT!
02-22-2008, 04:42 PM
NV
The truck parts (Typhoon or Syclone parts) are actually from a van...
Ken
02-22-2008, 06:52 PM
With the all wheel drive, looking at a total weight of the Cobra at a little under 2200lbs. It may not be an improvement but it will be fun to find out!
02-23-2008, 04:35 AM
I have all the AWD parts collected. Was going to put them into a F5 GTM but the funding for the project dried up .T-56 trans/Syclone transfer case, 2 Franklin IRS quik change rears, one for the front and one for the rear. CorvetteC5 spindles are the same front and rear , just put rear bearings in the front spindles so you have the drive splines for the CVs. 2200lbs is optimistic
