Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Shelby American, Inc.
Old 09-30-2011, 07:29 AM
snakehunter's Avatar
Cobra Make, Engine: CSX4158, alloy body. The Watersnake!
Default Fuel tank vent hose(s) ?
When we got 4158, the fuel tank filler neck had a welded 3/8 nipple near the top, with a 3/8 hose drop for an overflow or vent.
However it also had an an 8 fitting on the tank itself, with a 1/2" hose looped around itself and zip tied to the frame. Hose was just pushed on to the fitting and clamped - which seems a little rigged.
Are these both vents? Seems like the AN fitting should connect to the filler vent itself, rather than 2 lines.
Old 09-30-2011, 08:13 AM
Hotfingrs's Avatar
One is to vent the tank as you put in fuel. If you have a sealed gas cap, the other is to let air in while running. I've got a check ball on the tank vent, so that if you flip over it blocks off the vent.
Jack
XSSIVE .....
Old 09-30-2011, 09:13 AM
ahh...sealed cap, I hadn't thought of that....Just assumed the lemans cap was naturally vented.
Old 09-30-2011, 09:38 AM
mickmate's Avatar
Here's the -8 valve I use Summit Racing SUM-G3115 - Summit Racing® Fuel Cell Tip Valves - Overview - SummitRacing.com
I use a compressed air muffler on the end of the hose also.
mickmate
http://www.actoncustom.com/
Old 10-03-2011, 08:16 AM
Good idea - do you just have it installed onto the tank, or between the hose and muffler?
Also looked at our cap and it does have a vent hole. Should I just combine the two for the sake of redundancy?
Old 10-03-2011, 09:08 AM
mickmate's Avatar
I go from the vent through the tip over valve. From the valve I plumb up high behind an inner fender and put the muffler on the end as a breather.
mickmate
