Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Shelby American, Inc.
Old 05-06-2016, 02:08 PM
Default CSX8000 Radiator Hoses
Does anyone have the part numbers for the upper and lower radiator hose assemblies for the CSX8000/Slabside cars fitted with a SBF302
Old 05-06-2016, 05:10 PM
1985 CCX's Avatar
I used cardboard for pattern and went to local autozone.
Go out back as they have hundreds of diameters and bends.
Old 05-06-2016, 05:23 PM
Senile Club Cobra Member
Buy the owners manual from Blas, the hose numbers that work are listed in it. And a lot more.
spfwiringdiagrams@Comcast.net And don't let the "SPF" throw you, he does all of the manuals for the Hi Tech built and Shelby sourced cars.
rick@autoventureusa.net
Old 05-07-2016, 05:06 AM
Shootnride's Avatar
Cobra Make, Engine: Superformance, 427SO
You may be able to find what you're looking for here. I did.
http://www.gates.com/~/media/files/g..._web.pdf?la=en
Ted
Old 05-20-2016, 01:24 PM
Thanks Guys, sorted
Just a heads up, if you're ever changing a water pump from LH to RH, make sure you have the timing cover without the hall sensor, alternatively the sensor mounting can be hacksawed off insitu, in 5mins and then dressed so it is hardly noticeable.
Install a 2 o'çlock timing pointer, transfer the timing marks over and then install the pump
New length bolts are required for the pump
New alternator bracket mounting bushes will be required
Rob
Display Modes
