Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Shelby American, Inc.
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 07-08-2017, 12:38 PM
dcdoug's Avatar
Default Replacement clutch slave cylinder line
I need to replace this clutch line that runs from the slave cylinder to the adaptor fitting on the bulk head of CSX 6022. The line is just under 10.5" long from tip of fitting to tip of fitting. Does anyone have a part number or know where I can get one of these lines? Or do I need to have one made up?
www.partskeeper.com
Old 07-08-2017, 01:07 PM
https://www.holley.com/products/plum...ts/63010210ERL
In stock at Summit
https://www.summitracing.com/parts/ear-63010210erl
Or if your after the cheaper OEM look black line as removed, any NAPA should be a be able to match it up (10mm/.375" banjo and -3AN fitting)
Old 07-08-2017, 01:42 PM
dcdoug's Avatar
Perfect, thanks spdbrake!
www.partskeeper.com
Display Modes
