Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Shelby American, Inc.
Like Tree8Likes
Old 08-31-2020, 02:01 PM
t walgamuth's Avatar
softer pads will likely do the trick....finding some is a problem though.
Old 08-31-2020, 03:46 PM
Cobra Make, Engine: Shelby CSX6000, Superformance MKIII, Factory Five 289 FIA custom
Cool, I’ll try it.
Old 08-31-2020, 02:22 PM
twobjshelbys's Avatar
Brake pads don't wear out because they've sat on the car. It's likely the pads that are there were never properly bedded... A good hot run would probably make a world of difference. Change the brake (and clutch, and coolant and rear end and ...) fluids and then bed the brakes you have. You've got nothing to lose and will probably save your self some money and time. I had to run mine because they squeaked and made grinding noises like gravel.
Tony
CSX4005LA
Old 08-31-2020, 03:47 PM
The rear end makes a noise and clunk around corners, so I planned to change the fluid. I guess it makes sense to do everything; cooling system, brakes, clutch, rear end. Is that everything?
Old 08-31-2020, 03:52 PM
Engine oil and filter of course.
Tony
CSX4005LA
Old 08-31-2020, 05:09 PM
Good catch. I knew I missed an important part.
Old 09-01-2020, 06:39 PM
BigGuy's Avatar
Cobra Make, Engine: CSX4xxx, Alum. Shelby 427 w/ Webers,
I have a CSX 47xx that I’ve owned for 20 years. I just rebuilt engine, carbs sent to Jim Ingese in FL, Brakes, recoated sidepipes, new tires, etc.
The brakes are Baer in my CSX4700 (are red with White Shelby lettering on the outside). If you need calipers mustang “R” front and corvette rear. ( ‘95 mustang “R” and ‘84 Corvette four piston).
The three reservoirs are Girling’s (two large are brakes and one small is clutch) need to be completely flushed if your car sat for awhile, as mine sat for a few years because of my issues. I had to replace with new Girling reservoirs (Finish. line) they are so thin that after many years they just don’t seal ( gasket disintegrated).
If your pads need to have a good brake-in, give it a hard drive and get them hot, someone told me once to ride them to get really good and hot.
Jon
Old 09-02-2020, 03:49 AM
The silicone fluid works pretty well but will eat natural rubber seals. With good synthetic seals it is benign. It softens the natural rubber and though it will seal a minor seep it can eat away the seals in no time.
MKS427 likes this.
Old 09-02-2020, 10:30 AM
ERA 626's Avatar
Cobra Make, Engine: CSX 6079 482CI CSX cross ram
The 3 black canisters: the small one is the clutch the other 2 are front and rear brakes.
Old 09-02-2020, 10:45 PM
CompClassics's Avatar
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
I’ll send you a private message tomorrow and post photos. It is a very easy modification that gives you 2x the brake pedal pressure that the stock brake master cylinder has. I mounted one on a CSX6000 Series Continuation Cobra directly under the alternator on the main frame rail, you wouldn’t even know it was there when looking in the engine compartment.
Old 09-03-2020, 02:10 PM
Thanks
Old 05-02-2021, 10:23 AM
ERA 626's Avatar
please send me this info!!
Old 09-03-2020, 04:52 AM
MKS427's Avatar
Cobra Make, Engine: FFR MkIV 427
Don't forget trans fluid.
I'd check with Baer, to see which fluid and pads they recommend. With the dual master w/balance bar, you'll want to verify that the masters are getting full stroke when bleeding and the push rods are aligned, not bound. Baer should have some videos or PDFs to walk you through it.
Old 09-03-2020, 05:11 PM
Cobra Make, Engine: CSX4000, 427
I think it’s a pad issue. I’m guessing you can stand on your brakes, and they basically do nothing.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
Old 09-03-2020, 07:46 PM
Yeap.
Old 05-01-2021, 03:41 PM
Bill Kesner's Avatar
Cobra Make, Engine: CSX4141
Hello CSXBill,
Read most of the replies to you. I've got an early 4000 series with Wilwood brakes. Do you remember how your brakes felt the last time it was running? Car's do funny things when they sit for a while! I would first jack the front end up, and see if your wheels move freely. Just want to ensure your pads aren't sticking? Should be able to freely spin both wheels. Do the same for the rear. Next check your reservoirs. The small one towards the nose should be your clutch. The one nearest your firewall should be your front brakes, and center for rears. Let me know where your fluid levels are? Don't need to bleed your clutch just yet, since we're working on your braking issue. If your levels are good, take the car around the block where you wont have to brake on a hill or such, and warm the brakes up. Could be it just sat too long. I just got my car running again after 7 years, and all is good except for a leaking front master cylinder in the foot box, but I still have brakes! Will be replacing it soon!
- Bill -
Old 05-02-2021, 12:16 AM
Cobra Make, Engine: CSX 4145, aluminum body and Shelby aluminum FE stroker
I have the same issue with my CSX4145. Girling brakes. Rock hard pedal, very little braking considering the pedal effort expended (a LOT). Had my shop try all sorts of combinations of master cylinder configurations, and we did also put in softer pads, and nothing seemed to make any difference. Finally gave up and decided to live with it, because it WILL brake acceptably well; it just requires a truly immense amount of pedal pressure, which at this point I have gotten used to. And I don’t drive the car all that much. We figured the only thing left to try is to send the calipers in for a rebuild and see if that helps. Might try that someday.
Old 05-02-2021, 01:31 PM
For anybody interested doubling your brake pressure at the wheels without a lot of unneeded modifications please contact me using my email at jkb5 AT sbcglobal DOT net
The installation requires the fabrication of two brake pipes and a mounting bracket for the miniature power brake servo which requires a engine vacuum source.
Display Modes
