| 29 |
8Likes
08-31-2020, 03:44 PM
Cobra Make, Engine: Shelby CSX6000, Superformance MKIII, Factory Five 289 FIA custom
Originally Posted by twobjshelbys
Yes, sorry, there are three.
They will likely have the same fluid. Or at least mine did. DOT 3 as I recall for both brakes and clutch. It sort of doesn't matter - if it hasn't been serviced all of them need changing. (No matter what the fluid is contributing to the problem). Not knowing the service history you should just change everything that runs. If it's liquid, change it.
How do you do the clutch?
08-31-2020, 03:46 PM
Originally Posted by t walgamuth
softer pads will likely do the trick....finding some is a problem though.
Cool, I’ll try it.
08-31-2020, 03:47 PM
Brake pads don't wear out because they've sat on the car. It's likely the pads that are there were never properly bedded... A good hot run would probably make a world of difference. Change the brake (and clutch, and coolant and rear end and ...) fluids and then bed the brakes you have. You've got nothing to lose and will probably save your self some money and time. I had to run mine because they squeaked and made grinding noises like gravel.
The rear end makes a noise and clunk around corners, so I planned to change the fluid. I guess it makes sense to do everything; cooling system, brakes, clutch, rear end. Is that everything?
08-31-2020, 03:49 PM
NV
You mean drain? It depends on whether you have a conventional master/external slave or a master/hydraulic throw out bearing. The HTOB went out on me twice so I replaced it with a conventional. In any case, my mechanic did the fluid change (only guy I ever trusted to drive any of my cars) so I can't say from experience...
CSX4005LA
08-31-2020, 03:52 PM
NV
Engine oil and filter of course.
CSX4005LA
08-31-2020, 05:09 PM
Good catch. I knew I missed an important part.
09-01-2020, 06:39 PM
OH
Cobra Make, Engine: CSX4xxx, Alum. Shelby 427 w/ Webers,
I have a CSX 47xx that I’ve owned for 20 years. I just rebuilt engine, carbs sent to Jim Ingese in FL, Brakes, recoated sidepipes, new tires, etc.
The brakes are Baer in my CSX4700 (are red with White Shelby lettering on the outside). If you need calipers mustang “R” front and corvette rear. ( ‘95 mustang “R” and ‘84 Corvette four piston).
The three reservoirs are Girling’s (two large are brakes and one small is clutch) need to be completely flushed if your car sat for awhile, as mine sat for a few years because of my issues. I had to replace with new Girling reservoirs (Finish. line) they are so thin that after many years they just don’t seal ( gasket disintegrated).
If your pads need to have a good brake-in, give it a hard drive and get them hot, someone told me once to ride them to get really good and hot.
Jon
Reason: Spelling
09-01-2020, 06:48 PM
AL
I worked on a B&B with Ford brake a few years back and it would not stop. Well it did but took 200 - 300 ft. Scary!
I changed the brake fluid for Dot 3/4 synthetic. Then I could lock up the tires.
09-01-2020, 07:16 PM
OH
Dot 3 is fine doing a switch to 4, can make cottage cheese worse.
My .02
Jon
09-01-2020, 07:42 PM
AL
got this from Speedway site
What Is Brake Fluid Made Of?
If you look at the chemistry behind most brake fluid, it comes from the combination of various types of glycols, which are basically a mixture of non-petroleum and other alcohol-based fluids. After a mixing process, the chemical name gets shortened to “polyglycol”. In addition, there are also high-grade silicone-based fluids, which cannot be mixed with any other type of fluid. So whether it's used in the brake or clutch system, it's important to understand the differences between these common types of brake fluid.
The brake fluid must maintain specific properties. Our brakes can get hot, sometimes up to 1200 degrees, so the fluid needs a high boiling point. Also, because our vehicles experience seasons just as we do, it’s important to have low freezing point as well. On top of maintaining both extremes, it's designed not to damage any rubber components in the brake system.
brake fluid properties
As a result, the chemical properties found in most brake fluids can permanently dull or damage paint. So be sure to handle with care and be quick to clean any accidental overspills. Brake fluid is hydroscopic, meaning it has a natural tendency to absorb moisture. And over enough time the added moisture can result in corrosion build up or a decreased boiling point. It’s never a bad idea to change your brake fluid every couple of years and try not to leave your reservoir cap off any longer than needed.
DOT 3 vs DOT 4
DOT 3
DOT 3 is the most common type of brake fluid used in domestic cars and trucks. According to the Society of Automotive Engineers (SAE), DOT 3 can absorb 2 percent of its volume in water every year. Over enough time excessive moisture will cause corrosion in the brake system which can lead to issues like vapor-lock or a spongy pedal.
DOT 4
DOT 4 is formulated for use by all vehicles, it has a higher boiling point than DOT 3 and it does not absorb moisture as fast. DOT 4 and DOT 3 are interchangeable, however it's best to avoid adding DOT 3 fluid to a system that already uses DOT 4. It's the preferred type of fluid used for street and high performance applications. Almost all of the brake fluids Speedway offers from Afco, Wilwood, and Ultra Lite will meet or exceed DOT 4 requirements.
I added the bold print so it would be easier for the speed readers
Dwight
09-01-2020, 07:47 PM
AL
there is a 45 degree F difference in the boiling point of Dot 3 and 4.
Not enough to make any difference on a street car.
09-01-2020, 07:58 PM
AL
found this also
In practice, you can go up in DOT rating as long as it is the same base material. Mainly regarding your comment about mixing glycol based DOT 3 and glycol based DOT 4 is half true/misleading. You can mix the two and it will suffice for a system needing the DOT 3 rating but will boil and therefore have moisture/system issues in a system requiring DOT 4. Why does that matter? You can flush a DOT 3 system and fill it with DOT 5.1, the DOT standard is just a specification for characteristics of the hydraulic fluid. – finleyarcher Sep 26 '17 at 19:51
The glycol vs silicone is true because they don't actually mix, so you have two separate fluids acting in the system, which generally results in inconsistent hydraulic pressure as the fluids resist each other. It would be just like mixing engine oil with water. – finleyarcher Sep 26 '17 at 19:52
@finleyarcher I wondered whether that was the case. I have since heard of cases where the rubber s4als whcih 'prefer' one type disintigrate if they're used with the other. Eg on my morris traveller, it expects Glycol-based fluid. If I put silicone in (even if all new gear and fluid), the rubber seals might not like it. – user2808054 Feb 13 '19 at 10:22
09-01-2020, 08:26 PM
Originally Posted by BigGuy
I have a CSX 47xx that I’ve owned for 20 years. I just rebuilt engine, Brakes, recoated sidepipes, etc.
The brakes are Baer in my CSX4700 (are red with White Shelby on the outside). If you need rotors mustang “R” front and corvette rear.
The three reservoirs are Girling’s (two large and one small) need to be completely flushed if your car sat for awhile, as mine sat for a few years because of my issues. I had to replace with new Girling reservoirs (Finish. line) they are so thin that after many years they just don’t seal ( gasket disintegrated).
If your pads need to have a good brake-in, give it a hard drive and get them hot, someone told me once to ride them to get good and hot.
Thanks. What pads do they use? Mustang R and corvette (what year)?
09-01-2020, 08:29 PM
DOT 3 vs DOT 4
DOT 3
DOT 4
Dwight
Great info!
09-02-2020, 03:30 AM
Get Porterfield Semi-Metallic Pads. If you can not find them for some reason, call McCluskey LTD in California, 310-375-1234.
09-02-2020, 03:49 AM
IN
The silicone fluid works pretty well but will eat natural rubber seals. With good synthetic seals it is benign. It softens the natural rubber and though it will seal a minor seep it can eat away the seals in no time.
09-02-2020, 10:30 AM
The 3 black canisters: the small one is the clutch the other 2 are front and rear brakes.
09-02-2020, 10:45 PM
I’ll send you a private message tomorrow and post photos. It is a very easy modification that gives you 2x the brake pedal pressure that the stock brake master cylinder has. I mounted one on a CSX6000 Series Continuation Cobra directly under the alternator on the main frame rail, you wouldn’t even know it was there when looking in the engine compartment.
09-03-2020, 04:52 AM
Cobra Make, Engine: FFR MkIV 427
Don't forget trans fluid.
I'd check with Baer, to see which fluid and pads they recommend. With the dual master w/balance bar, you'll want to verify that the masters are getting full stroke when bleeding and the push rods are aligned, not bound. Baer should have some videos or PDFs to walk you through it.
09-03-2020, 02:10 PM
