02-15-2008, 08:50 AM
CAV built the first bunch of 4750 cars before they closed up. As mentioned, they had quite a bit of issues.
Sal Mennella
02-15-2008, 11:48 AM
Ride Height
Quick question maybe Steve S or someone else can answer. I had a great alignment done but I would like to lower the car about an inch. Am I going to throw off the alignment by lowering the car?
02-15-2008, 11:52 AM
fl
Cobra Make, Engine: Kirkham #473 427 every option, Keithcraft aluminum FE 482 ci. Mass Flo FI. Tremec TKO 600.
Yes, alignment will change if you lower the car.
02-15-2008, 01:25 PM
If you have a good set up to start with it shouldn't be affected much. Having said that the toe changes through the suspensions travel. That has a big effect on a short wheelbase car like these.
02-15-2008, 03:35 PM
Cobra Make, Engine: CSX4000 w/CSXblock
CAV built less than a dozen cars.
02-18-2008, 08:41 AM
More like 6 cobra's before they folded. They were in trouble from the start. It seams everything they did had to be done over rom the color of the frames to the mismatched bolts.
Morgan LeBlanc
Fresno CA
02-18-2008, 10:14 AM
NJ
Sal
Anything you change will yield a reaction in more than just alignment. Lowering the car will change corner weights as well as cross weights and roll centers. You will know it on the track but maybe not on the street.
If you are going to change anything, plan on changing everything so, anything that possibly didn't need changing was at the very least,,,,,,,,,,checked.
03-03-2009, 07:03 AM
HH
Cobra Make, Engine: Alum 427 S/C with KC FE 482 Shelby
Having read all the above I think I understood where the fibre cars are now being made.
What I have not found is an information about the non-fibre version. Is that still manufactured for Shelby by Kirkham?
03-03-2009, 07:05 AM
SC
Yes..........
03-03-2009, 07:08 AM
HH
Wow - This was fast - Thanks a lot - So one can expect that those are not facing the same problems like the fibre versions - That is good news......
03-03-2009, 07:48 AM
Lurk: Is that if she's hanging on to your neck???
03-03-2009, 09:30 AM
There are a couple of others that still make ally bodies by hand. http://www.mccluskeyltd.com/
and http://www.panel-craft.com
03-03-2009, 09:47 AM
HH
Thanks so much - I wasn´t aware of this.....
So there it is again: Variety..........To the good or to the bad - I guess I will only know once I have finalized mind games and made my choice (and have taken delivery  )
It is pittyful and interesting at the same time that the (my?) level of transparency in regard to the non-fibre and non-carbon choices is not more detailed.
Even finding out the real differences between Kirkham and CSX package (dispite suspension issues) is pretty tough I feel.
Has there ever been a comparison in regard to the real physical differences of the cars in regard to what they DO NOT have in common (excpet CSX and KMP number)?
Anyone who can help with related information? Would be phantastic and highly appreciated!
Carsten
03-03-2009, 10:09 AM
Too much for my hen peck typing.
03-03-2009, 11:13 AM
Cobra Make, Engine: KMP-216S Kirkham Street '66 428 PI
Hey Racer,
Go to Roger Krause Racing in Hayward. He did 'em back in the day and has done tons of Kirkhams and CSX cars.
They're linked at Kirkhams web site.
K
03-03-2009, 08:33 PM
NV
Cobra Make, Engine: 427 SC
NC427, Not all of them are made by Kirkham. Shelby has a vendor in England who is also making aluminum bodies for them.
Originally Posted by mrmustang
Yes..........
Do you just like to see yourself post? You should at least be right before you do so.
03-03-2009, 08:42 PM
SC
So, bad day at the office/shop?
Dave Kirkham's own signature line (current) states the following:
Supplier of frames and aluminum bodies to Shelby* for their CSX4000, CSX7000, and CSX8000 289 and 427 Cobra
As for the response to his original question as posted, the correct answer was YES. He did not split hairs, not quite sure why you are at this point in time either.
Bill S.
03-10-2009, 12:41 PM
hi have any of you guy's seen or heard of the new cobras from england with hand made original ally bodies and chassis the way they should be made. I here shelby has four at the moment
03-10-2009, 02:44 PM
UT
Cobra Make, Engine: Polished KMP #488 / 427SC, 427 SO/482 by KC
mmmmm....
must bite tongue!
01-30-2010, 11:46 AM
Cobra Make, Engine: TBD
Need Some help,
I sat in three CSX cars yesterday and trying to make a decision on making a commit to buying one. I sat in a car yesterday that is an HST and the steering wheel was 2"-3" lower than the wheel in my CSX4264, it actually rested on the tops of my thighs and not comfortable, the trunk latch had to turn under the license plate.
I am really close to making the decision for a a street roadster in San Jose.
What are the Differneces between a an HST manufactured CSX and one coming from Hi Tech out of SA. You would think there would not be a delta between them but, there appearantly is.
Tony R.
