Carroll Shelby - Shelby 427 FE Engine Parts and Services
s
Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Shelby Enterprises Inc.
User Name
Password
Club Cobra Home Register FAQ Members List Calendar Today's Posts
Old 08-30-2015, 05:23 PM
Default CSX 4000 fuel filter
Can anyone tell me where it is located on a CSX 4000 car. Don't have a lift here. How about a part # to ... ;-)
Dan
427 CSX 3000/4000 and Shelbys.
All gone ! Was a Hell of a run
Now ... The dogs car
Mercedes E63S station wagon. 603hp
Old 08-30-2015, 08:44 PM
Bernica's Avatar
Senior CC Premier Member
Both of mine are located right under the drivers seat area. One supply and one return..
Old 08-31-2015, 12:09 AM
CompClassics's Avatar
Is your car using the two electric pumps in the trunk on the passengers side? If so are the pumps the "Facet" cylinder style? If so there are filters inside the bottom of each pump, if you are running a mechanical pump the filter may be between the pump and the carb.
Old 08-31-2015, 05:47 AM
Electric ..thanks for the info.
Dan
Old 08-31-2015, 05:50 AM
Wonder if mine have that to..... Easy to check out to. Thanks guys.. It's today's job
Dan
Old 08-31-2015, 08:41 AM
Bernica's Avatar
Mine has the two electric pumps in trunk on passenger side as well as the 2 in-line filters below driver's seat side, then feeding a mechanical pump on the engine that does the daily work with a bypass to run the electrics if needed. I hope that makes sense...
Old 08-31-2015, 09:20 AM
Ya it does! I also don't understand 2 electric pumps.
Dan
Old 08-31-2015, 10:15 AM
Bernica's Avatar
There should be a switch on the dash that fires up the electric pumps (you will hear them thumping and slowing down after pressure is built up). I usually run them only on startup routine, then turn them off and let the mech pump do the work. I am told that the electrics are for backup or when you are running low on fuel. I leave them off during regular driving.
I'm sure someone will correct me if I am wrong..
Old 08-31-2015, 10:30 AM
Shelby initially used two electric (240A Stewart Warner) pumps mounted in the same location on The original 427 Cobras of the 1960s. I believe the original installation was done for redundancy, the only problem was that if one pump failed it usually took out the other pump as well because the two pumps used the same power supply circuit and either of the pumps failing caused the fuse for the fuel pump circuit to blow.
Old 08-31-2015, 10:46 AM
Bernica's Avatar
Yes, I believe all true. If you want to go crazy safe, there is actually a spare wire back there for a differential cooler that is/was rarely used, so in principal you could isolate the two pumps by using that one. I have no idea why you need a circuit for a diff cooler, but that's what the wiring diagram says...
Old 08-31-2015, 11:13 AM
The Facet pumps utilize solid state circuitry so the chances of blowing the fuse are almost nonexistent in comparison to the Stewart Warner pumps which used points.
Old 08-31-2015, 01:13 PM
OK found one filter in the feed line up by the front of the foot box. Had 2 small ones on the carb itself. They were clean. Need to find something I can drain gas in to check the one under the car. I am not at home where I have everything and a lift I noticed the 2 elect pumps had filters on the bottoms. Will much gas come out of them. ?? Also how much fuel pressure should I have ??? Alum BB.
I am starting to miss my little ol V6 Turbo already
Dan
Old 08-31-2015, 01:46 PM
Bernica's Avatar
I believe 7 lbs is about max for pressure on a carb engine. Much more for FI.
Good luck!
Welcome, from Carroll Shelby
Have you noticed that it's tough finding quality performance parts to build a reliable FE engine? I have and I decided to do something about it by introducing my own line of Shelby FE™ performance parts. I worked with my design staff to build the best, because my name is on them. My racing legacy with FE performance engines extends back to my race winning 427 Cobras and GT-40 Mk.IV racers that won LeMans. Three decades later, my newer Shelby FE™ parts utilize proven design refinement to create FE performance parts for the new millennium.
My catalog illustrates an overall selection of parts available, but we can supply complete engines or parts from oil pan to carburetor to build your own Shelby 427 FE™ aluminum or cast iron engine just the way you want it. Call and speak directly to our engine department with your tech questions and orders. You have my name on it.
~ Carroll Shelby
Engine Home  |  About the Shelby 427 FE  |  Engine Parts  |  Contact  |  Tires Home
CARROLL SHELBY ENTERPRISES, INC.
19021 S. Figueroa St.
Gardena, CA 90248-4510
Tel : 310-538-2914
Fax : 310-538-1815
