Carroll Shelby - Shelby 427 FE Engine Parts and Services
s
Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Shelby Enterprises Inc.
User Name
Password
Club Cobra Home Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Old 05-13-2004, 06:30 AM
Roxie_427's Avatar
Cobra Make, Engine: Shell Valley, Shelby Aluminum 427, stroked
Send a message via AIM to Roxie_427
Default Shelby Forged Pistons
Chris,
Who is the manufacturer of your forged shelf pistons? I'm planning to use a SCAT 428 crank (3.98 stroke) and Eagle rods (6.490) with a Shelby aluminum block.
I'm finalizing my research on 427 parts and readying for a purchase.
Thanks,
Tim Terry
Seabrook, TX
Old 05-13-2004, 11:53 AM
Tim,
Our shelf pistons used to be from Arias and Ross, and we still have some inventory of those.
We now have our own pistons, which are about 100 grams lighter than the other FE pistons we have had our hands on. Our forging die has all the extra material removed from underneath the piston crown, except where FE valve reliefs are (excluding Cammer of course).
We stock a wide variety pistons, or if you have a custom or unusual application, we can finish a set to your spec. Within reason, we can do whatever bore diameter, compression ratio, pin height and bore, and ring package you'd like. Minimum bore for our forgings is stock 427 (4.233").
These are not reboxed other-brand pistons. They are produced from our own forging die, made specifically for FE's.
We are the largest stocking dealer of FE products from Scat, so maybe we can put together a package deal for you on pistons, rods, crankshaft, and block. We could even turn it into a shortblock for you.
Chris Weisberg
Carroll Shelby Enterprises
(310) 538-2914
Old 05-13-2004, 12:09 PM
Old 05-13-2004, 02:34 PM
wilf leek's Avatar
Cobra Make, Engine: Crendon, windsor 408 stroker, tremec. Also GSX008
Chris - those pics are pure art. Thanks
Question - very short skirts on those slugs - is that where you saved the weight? Or is it "normal" for an FE piston?
Wilf
Old 05-13-2004, 04:54 PM
Thanks Wilf,
I agree! We have a customer who bought just one piston and two rocker arms, to make a display for his desk.
Those skirts are normal length. They may seem short because a stock 427 piston has a low pin height in comparison.
Ours is about 100 grams lighter than an identical piston made off a standard forging! The weight was saved by having a dedicated forging. The material was placed only where it needed to be (ring lands, valve relief pads, pin towers, etc.). Normal Brand-X FE pistons are made from a universal forging, so they have excess material underneath the piston crown to allow the same blank forging to be used for multiple engines with various valve configurations. Ours, on the other hand, are only applicable to non-Cammer FE's.
When I hired on, Carroll's orders were to continue to develop the existing Shelby FE. I think these pistons came out pretty nice, and there are more goodies on the way.
Chris Weisberg
(310) 538-2914
Rate This Thread:
Welcome, from Carroll Shelby
Have you noticed that it's tough finding quality performance parts to build a reliable FE engine? I have and I decided to do something about it by introducing my own line of Shelby FE™ performance parts. I worked with my design staff to build the best, because my name is on them. My racing legacy with FE performance engines extends back to my race winning 427 Cobras and GT-40 Mk.IV racers that won LeMans. Three decades later, my newer Shelby FE™ parts utilize proven design refinement to create FE performance parts for the new millennium.
My catalog illustrates an overall selection of parts available, but we can supply complete engines or parts from oil pan to carburetor to build your own Shelby 427 FE™ aluminum or cast iron engine just the way you want it. Call and speak directly to our engine department with your tech questions and orders. You have my name on it.
~ Carroll Shelby
Engine Home  |  About the Shelby 427 FE  |  Engine Parts  |  Contact  |  Tires Home
CARROLL SHELBY ENTERPRISES, INC.
19021 S. Figueroa St.
Gardena, CA 90248-4510
Tel : 310-538-2914
Fax : 310-538-1815
