Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Shell Valley Companies
Old 12-06-2018, 08:35 AM
Registered User
Cobra Make, Engine: Shell Valley, 460
Default Rear Shock Mount Torque Specs
Hi, Does anyone know the proper torque specs for the rear shock top mounting bolt? It has a lock nut on one end.
And if anyone has a scan of an assembly manual for a 2007...
Thanks!
Old 12-06-2018, 10:15 AM
cycleguy55's Avatar
Thanks!
Coil-overs:
If you have stud-mount shocks:
How tight should the nut be on stud top shocks?
It’s important that the nut on stud top shocks are correctly tightened. If the nut is too tight, it can cause premature wear and binding in the suspension. If it’s too loose, there won’t be enough thread to install the jam nut, which could potentially cause the shock to fall out of place. We recommend that the nut on stud top shocks be tightened until the bushing is the same diameter as the steel washer. This will help to ensure all mounting hardware is tight enough to hold the shock in place.When tightening or loosening the nut, we do not recommend using an impact gun, as it has the potential to break the stud or unscrew the piston from the piston rod. The piston rod is machined with "flats" allowing it to be held with a wrench while tightening or loosening the nut.
https://www.qa1.net/technical-suppor...g-faqs#fifteen
Brian
Old 12-08-2018, 05:27 AM
Registered User
Thank you for the assistance!
Old 12-08-2018, 01:35 PM
Cobra Make, Engine: Shell Valley, 351W
At least for a 2003 model with coil over shocks, SV says that the rear shocks and rear control arm bolts should be tightened to just snug and backed off 1/4 turn. This is to minimize any potential binding in suspension travel. Last year I developed some squeaks in the rear suspension travel so I replaced all of the rear shock and control arm bolts. I installed the new bolts with a little anti seize and followed those specs. Then made sure that i could twist the bolts a little when completed.
Old 12-08-2018, 02:20 PM
cycleguy55's Avatar
That makes sense, as long as those fasteners are Nyloc or some other self-locking nut, or have cotter pins to stop them from backing off.
Brian
Old 12-08-2018, 04:39 PM
Yep. I replaced the original Nyloc nuts with some distorted thread type lock nuts. I sleep better now.
