| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
04-03-2003, 11:51 AM
Hood stop
I am looking for some good ideas on how to stop the hood from opening to far and damaging the paint !
04-03-2003, 12:05 PM
Why are you opening the hood that far? Do you have a hood prop?
04-03-2003, 01:14 PM
I do plan on using the prop but I am just afraid that some time some place if I do nothing to stop it it will get into the paint if not by me, then by a well meaning frend, or a gust of wind ECT.
But if no one else has had such trouble I may just let it go I need input. Thanks
04-03-2003, 04:49 PM
WA
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Mine has chromed sliders
No way it can go past a certain point, and it also has a ratcheting catch at the top to keep the hood propped. Not sure where you would get them for other cobra makes, but it seems the set I have could be adapted. Mine came from West Coast on my turnkey.. it was an option.
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
04-03-2003, 04:58 PM
Thats what I would like to have on mine, but I am not sure where
I would mount the slider on the lower end, there are no real inerfenders. Do you have some sort of bracket at the edge of the hood opening?
04-11-2003, 06:09 PM
ME
Cobra Make, Engine: Shell Valley 351W Tremec 2004 Cobra SVT Convertible
Rick
I used a prop rod that Finish Line sells. It is made of stainless and has a bracket I mounted to the frame, The bracket has a detent in it so it won't allow the hood to open to far. The bracket also stores the rod when the hood is closed.
HOG
04-11-2003, 06:49 PM
tx
Cobra Make, Engine: Keith Craft Motor
My prop rod needs to be moved when the hood comes down, I think (hope) this would stop any gust from blowing it open
todd
04-11-2003, 06:51 PM
IL
Cobra Make, Engine: Shell Valley, 351 Sportsman
Saw an intersting hood support on eBay. Is this a Backdraft?
D:\Cobra Ebay\Ebay Listings D\eBay Item 2410525443.htm
04-11-2003, 06:58 PM
CA
Rick,
I used one from a MBG. It has a tab you push down to release it so you can lower it. You can buy one from Moss Motors for about $25. Thay have a similar bracket for the trunk. This one you lift up the trunk to release.
Paul
04-12-2003, 06:49 AM
Thanks for all the great info. Looks like the one from Finish line
will do just what I need thanks again to all of you for the help.
06-04-2003, 03:11 AM
VA.
Cobra Make, Engine: Shell Valley, LS1
Has anyone used a gas assisted prop on their Shell Valley? You know, the ones that helps hatchbacks lift thier hatch.
Red 99 Z28
2004 trailblazer
Green 93 Jeep Wrangler
Shell Valley 427 Cobra
2004 Yamaha XLT1200 Jet ski
06-04-2003, 04:28 AM
OK
Rick I have an extra that I once used on my hood, I got it from Enzo at Finish Line. You are welcome to mine if you want to try it. I will show you how and where to bolt it up to your hood. I am in Tulsa. Give me a call this weekend if you want to pick it up.
Actually, I live in Broken Arrow just east of Forest Ridge Golf Club.
918-357-9868.
Clois
"Let's roll"
"Be part of Something Good
06-04-2003, 06:10 AM
Thank you Clois that is very nice of you. I just went with the stock SV unit so I could get on with the car but I would love to find a better way. I will be out of town till mid week next week but I will give you a ring then if that would be ok? Looking forward to meeting you.
Rick
06-04-2003, 06:48 AM
CA
Cobra Make, Engine: Everett-Morrison, FE 428
red99z,
I have them on my EM.
Not a very good pic but you'll get the idea.
Gene
06-04-2003, 11:16 AM
VA.
Gene,
Do you have two on there or just one? Can you get me the specs on those by chance? (close length, open length, force, brand and maybe where I can find them)
Thanks
Matt
Red 99 Z28
2004 trailblazer
06-04-2003, 06:47 PM
CA
Matt,
There are 2 of them, one on each side of the hood. Here's the info right off the strut.
Eberhard Mfg Company
Cleveland, OH 44136-6697
Powerwise
8T00-120
That's all the info I can find.
The strut cylinder is about .750" Ø x 10.5" long. Total length expanded (as attached to hood) is around 20". It actually only compresses about 3" with the hood closed although it could compress much further if needed.
Here's some better pics
Gene
06-05-2003, 02:49 AM
VA.
Thanks for the info Gene; it’s much appreciated.
Matt
Red 99 Z28
2004 trailblazer
