Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Shell Valley Companies
Old 01-03-2004, 07:17 AM
Cobra Make, Engine: Shell Valley Cobra. Engine is a Ford Racing 302 Crate motor, with Tremec 3550 5 speed trans.
Default Shell Valley master cylinders
Hi people,
Here I go with my latest problem. Have a Shell Valley kit
with the two brake master cylinders. The instruction manual leaves a bit to be desired in plumbing the brakes. For instance, which master is for the front brakes----the driver side or passenger side cylinder. The driver side appears to be a larger bore, so I assume it is for the front brakes, but would like to know for sure before I proceed.
Thanks.
JL1924
email: JL1924@optonline.net
Old 01-03-2004, 09:52 AM
Default brake cylinders
Call John at Shell Valley East in Conn. 1-877-221-1970 this is one of the resons Shell Valley opened a new location in Conn. To help car owner in the Eastern part of the country.
Old 01-05-2004, 09:17 AM
Default master cylinders
Just spoke to John From Shell Valley East. His tech advises the master cylinder with the largest bore goes to the front. Maybe this will help someone else also, and thanks again, John
JL1924
Old 01-05-2004, 09:46 AM
Cobra Make, Engine: Shell Valley, 514 SVO ... now a 4.6L with an AOD!
the larger bore master should go to the front. It should be the master cylinder closest to the engine.
Dana
