Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Shell Valley Companies
Old 01-03-2004, 07:17 AM
Cobra Make, Engine: Shell Valley Cobra. Engine is a Ford Racing 302 Crate motor, with Tremec 3550 5 speed trans.
Default Shell Valley master cylinders
Hi people,
Here I go with my latest problem. Have a Shell Valley kit
with the two brake master cylinders. The instruction manual leaves a bit to be desired in plumbing the brakes. For instance, which master is for the front brakes----the driver side or passenger side cylinder. The driver side appears to be a larger bore, so I assume it is for the front brakes, but would like to know for sure before I proceed.
Thanks.
JL1924
email: JL1924@optonline.net
Rate This Thread:
