Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Shell Valley Companies
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 03-23-2004, 06:04 PM
Cobra Make, Engine: Black Shell Valley with Silver stripes, 351 "Cleavor" powerplant
Default AC pedals on stock Shell Valley assembly?
I'm curious to see if any SV owners out there have ever discovered a set of AC pedals that can be adapted to the standard VW/Audi type pedal assembly that comes with the SV kit? I am looking for some type of pedal to adapt to my Shell Valley - any ideas? (Feel free to chime in Shell Valley!)
Old 03-23-2004, 07:33 PM
Brad, I have a Shell Valley.....I didn't use the SV pedals, but I used Wilwood pedals. I bought the AC pedal pads and then drilled and tapped the Wilwood pedal arms and just used the existing holes in the pads (for the little rubber inserts) to mount them. Looks good.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 03-24-2004, 10:58 AM
Cobra Make, Engine: shell valley, 302 ford racing
brad,
i didn't really like the SV pedals either, so i purchased the AC pedals, ground off the VW pedals and installed the AC pedals. was not really impressed with the final look so made some aluminum covers for the pedal "arms". i think it looks pretty good, it was not hard and it was inexepensive. before and after pics are im my gallery if you care to look. good luck ,
outlaw
Old 03-24-2004, 11:46 AM
flipper35's Avatar
Cobra Make, Engine: Shell Valley, Mopar thingy (small block of course)
Hmm, mine are all aluminum. Must have changed the design a bit.
Brent Dolphin
Old 03-30-2004, 09:05 AM
Cobra Make, Engine: CSX4761, KCR Shelby Alloy 496,760hp
Send a message via AIM to misfit41
I used the ac pedals on the SV setup,and flipped it over and mounted it from the floor,,it is turning out nice,,took a bit of time but it was cheap,Tim
Tk
"this whole Adult thing just isnt working for me "
Old 04-14-2004, 01:53 PM
Club Cobra Member
Cobra Make, Engine: Shell Valley. 427W , SB-100
I bought AC pedals from The Finish Line. I cut the flange off the SVC pedal arms and I cut slots in the mounting hubs of the ACs. A clevis pin holds the pedal to the arm. I also thought the SVC pedals were hokey...especially with the VW rubber pads! I can send pix if desired.
Dave
Old 04-14-2004, 06:15 PM
trctrdrvr's Avatar
heavy hauler
Cobra Make, Engine: Shell Valley stroked 342
Dave
can you send me a pic of what you did been thinking of the same thing, you will save me some time
thanks mike
mpbp43@outdrs.net
I Planted...Watered....But God gave the increase....
Old 04-15-2004, 07:11 PM
Dave, Please send me some pics - I still have yet to solve my dilemma, and you have aroused my interest again! Thanks, Brad
Old 04-15-2004, 10:01 PM
Club Cobra Member
Brad,
What's your email address? I'm having trouble attaching a pic to this. I can send via direct email. Basically I modified the SV arms, cut slots in the hubs on the back of the pedals and drilled holes for clevis pins.
Dave
Old 04-18-2004, 06:40 AM
My e-mail address is bscottlong@webtv.com - sorry, I forget to tell people these things from time to time! I think I understand what you described, but how did you cut the slots in the AC pedals? Did you have them machined, or did you do it yourself? Thanks for the tip - I think I'm going to buy a set and try it! Brad
Old 04-18-2004, 10:08 AM
trctrdrvr's Avatar
heavy hauler
Old 05-21-2004, 08:44 AM
Cobra Make, Engine: Shell Valley Cobra. Engine is a Ford Racing 302 Crate motor, with Tremec 3550 5 speed trans.
Attn. Dave Bermani,
If you still have a copy of the pictures you have of the pedal modifications, would appreciate a copy. Thanks.
JL1924
email: JL1924@optonline.net
Old 10-21-2004, 09:13 PM
Cobra Make, Engine: Shell Valley kit. Ford Racing 351W engine, with ATI Pro-Charger
Send a message via AIM to JoeGuentert
Brad - Just saw your posting, several months later. Did you find a solution yet?
I used some new FRPP pads, that just happened to fit perfectly, and look great. Let me know if you'd like photo's.
