Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Shell Valley Companies
Old 01-13-2005, 12:41 PM
Cobra Make, Engine: Shell Valley, 302, a work in progress
Default Fan Shroud?
What are you guys using for a fan shroud on your Shell Valleys?
Any pictures would be appreciated!
I have a 16" pusher fan and I am wondering if it will keep a bigger engine cool.
Thanks,
Killer
Old 01-13-2005, 12:54 PM
flipper35's Avatar
Cobra Make, Engine: Shell Valley, Mopar thingy (small block of course)
Just switched from a pusher (16" Permacool with fabricated aluminum shroud) to a puller. The puller should be in tonight and will let you know. The pusher had a small shroud around the blades only. The new one is slightly bigger, but still not a full sealed shroud. The pusher never did keep the real cool at idle, it would get above 210* in the 110*+ heat here but would keep it below 200 back in Wisconsin.
Brent Dolphin
Old 01-13-2005, 02:06 PM
I also have a "puller" on my S.V. No shroud other than the fan housing. It stays cool without any problems.
Rate This Thread:
