Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Shell Valley Companies
Old 07-29-2005, 09:31 PM
Cobra Make, Engine: Shell Valley 427S/C with 1964 427 center oiler
Default Need help with Throttle linkage
Guys,
HAving a real hard time with the linkage supplied by SVC. Just cannot getting it to wide open throttle with the supplies I have. Could anyone email or post pictures of thier linkage and how it is set up so that I can see how others have rigged it to work. It feels like I have tried everything, but there must be a way. Maybe I have the short an long legs reversed. I just do not know.
Help.
Romanbuilt
...there is no replacement for displacement!
Old 08-29-2006, 02:40 PM
trctrdrvr's Avatar
heavy hauler
Cobra Make, Engine: Shell Valley stroked 342
Send me your email address and I will send you pics of my linkage, I used some of SV stuff and fabricated the rest.
mpbp43@sbcglobal.net
I Planted...Watered....But God gave the increase....
Old 08-29-2006, 05:43 PM
elgecko's Avatar
Cobra Make, Engine: Scratch build......a little every day.
I sure would like to see pics of your setup also.
I'll sent you an email.
Dave
55 mph is unsafe at any speed. Huh?
Old 10-20-2006, 07:12 PM
Average Guy
I also had to do some fabricating on my linkage. The pedal assembly was OK and the linkage between the carburetor and firewall was OK, but I had to make a piece to connect the pedal linkage to the linkage on the firewall. It turned out fine and gives me some adjustability of the pedal height.
Old 10-20-2006, 08:01 PM
Clois Harlan's Avatar
Romanbuilt,
My guess your levers are slipping on the rod that runs parallel to your fire wall. I would suggest that either you spot weld them in place or drill a small hole thru the lever and rod and use a roll pin once you get everything in the position you want.
Clois
"Let's roll"
"Be part of Something Good
