Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Shell Valley Companies
Old 06-07-2007, 04:20 PM
blueovalfanatic's Avatar
Cobra Make, Engine: Shell Valley- 390 FE, 4 speed toploader, 3.50's
Default SVC guys with 17" wheels...
I am looking for the overall height of an "average" or "common" 17" wheel / tire combo- from the floor to the top of the tire. I am trying to compare them to the wheels and tires I currently have on my chassis (which will be used just to move the car around), so that I can install the transmission crosmember- as the manual says to install the engine so that the carb base on the intake is level.
The tire currently on the back is pretty tall, so what I am thinking is if the tire should be 2" smaller in height, I could raise the front of the frame 1" to compensate, and then level the carb base out to figure out where to bolt the crossmember in.
Also, I know that 295/50 R50's will fit, but these numbers mean nothing to me, as I have no idea how tall they are.
Greg
www.gregsgarage.20megsfree.com
Old 06-07-2007, 04:58 PM
Cobra Make, Engine: Shell Valley, 351W
Hi Greg,
My front tires are 235-45-17 with 24 psi are 24.5" tall. The rears are 285-40-17 with 26 psi at 25.25" tall. I didn't have my wheels and tires on yet when I installed the engine and transmission. i just made sure the frame was level on the jack stands when I leveled the carb base. It worked out fine. HTH
Sydney
Old 06-08-2007, 08:31 AM
CJ428CJ's Avatar
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
You can find what you're looking for at tirerack.com. Here's a direct link to the specs for the Michelin Pilot Sports. Other manufacturers may differ slightly but they'll be close: http://www.tirerack.com/tires/Spec.j...e1=yes&place=0
Chris
Old 06-08-2007, 12:03 PM
Terry Stapley's Avatar
Cobra Make, Engine: Shell Valley, 418W, tremec 3550tko, 9" ford rear, 3.0 gear, silver/black
Greg, 26" from floor to top of tire!!
285-40-17
Terry
Old 06-08-2007, 02:21 PM
Hmmm...OK, that makes sense. I never thought of it that way, as to level it with the frame itself. I guess the frame should be pretty level, as the pipes are bolted to them. LOL
Thanks CJ for the link. I will check it out. And thanks Terry. I forget how tall the ones are that are on it now, but I will go out and check.
Thanks, and have a great weekend!
Greg
