Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Shell Valley Companies
Old 04-27-2008, 01:59 PM
trctrdrvr's Avatar
heavy hauler
Cobra Make, Engine: Shell Valley stroked 342
Default seat belts
Can you guys with SV post a pics of how you mounted your seat belts think I have it figured out but always looking.
thanks Mike
I Planted...Watered....But God gave the increase....
Old 04-30-2008, 10:47 AM
Terry Stapley's Avatar
Cobra Make, Engine: Shell Valley, 418W, tremec 3550tko, 9" ford rear, 3.0 gear, silver/black
Mike, no pics but I mounted my belts running them over the tops of the seats and through the back cockpit wall and then bolted them to the frame where it kicks up behind the cockpit!
If I remember correctly (4 Years ago) I made an opening (2" Square) in the bottom fiberglass of the upper part of the trunk and drilled through the frame and then ran bolts all the way through! Good solid mounting spot!!
Terry
Old 04-30-2008, 07:52 PM
Cobra Make, Engine: Shell Valley, 351W
Hi Mike,
I modified my roll bar mounts by extending them up through the trunk and welding some tabs on them for the belts and another tie to the frame rails.
Sydney
Old 05-11-2008, 10:17 AM
trctrdrvr's Avatar
heavy hauler
thanks for your suggestions guys I ended up with mounting it thru the frame rail
