01-23-2010, 12:52 PM
MD
Roll bar cross member and 5/6pt belts
I currently have just lap belts in my CSX. I would like to take it to the track this year and need to install 5/6pt belts and a cross member mounting point for the roll bar.
What are the opinions on this x-member from finishline? Any others that I should consider? I am trying to keep my car as period correct looking as possible.
http://www.finishlineaccessories.com...7a578163211c30
Also, for the belts, recommendations? Ideally I would like to not add any new anchor points. Does that leave me with either 4pt belts or 6pt belts with the front straps attached to the seat track?
This 5pt kit from finishline seems to be period correct looking. Is it a good design? Are there 6pt options in this sort of style?
www.partskeeper.com
01-24-2010, 01:07 PM
while i can't comment on specifics on your car, i can tell you for NHRA the shoulder harness attach points cannot be higher that the highest point of contact on your body.
the between the leg strap must be attached to a steel frame member or steel strap under the seat attached to a frame member. the seat track attaching won't fly.
01-24-2010, 02:28 PM
Doug, can you do something like this? These are my Crow belts. BTW, any update on the oil?
EDIT -- Before anybody posts a warning, those bolts go to the chassis. But I would think that if Doug properly braced it from behind he could just drive the bolts straight through the aluminum bulkhead.
01-24-2010, 04:13 PM
UK
can anyone tell me what the width of the roll bar used in the picture?
- -or can the polished cross-bar be trimmed to the correct width?
01-24-2010, 05:35 PM
Hey Doug I just put a set of Simpsons in 6025 as they are SFI approved. The rear cowl bar is a perfect height for wrapping the shoulder straps around. It puts them right across the shoulders and 90 deg to the spine. I used the nice trim plates for them from Finishline. http://www.finishlineaccessories.com...roducts_id=228 I attached the submarine strap with a spacer to the steel channel for the sidepipe hanger as it is welded at both ends to the frame. I have some pictures I'll e-mail you. The roll bars are typically 12" on center but according to the Simpson install instructions those crossbars are too high. Patricks look like they are at the same height as the cowl hoop.
01-24-2010, 05:38 PM
I just thought of something else I have made plates to go between the seat bolts to attach a submarine strap but only if they bolt to the frame and yes I do use larger diameter rated bolts holding the plate and the seats.
01-24-2010, 05:59 PM
Cobra Make, Engine: CSX 4973
I'd like to see some pictures of that setup. I have been considering wrapping around the cowl bar but wasn't sure which belt I should use or how it would look/work.
01-24-2010, 07:48 PM
MD
Thanks for all the feedback on this. It's interesting that most feel that adding a cross member to the roll bar makes the angle too high for the shoulder belts. I believe that George Anderson told me that he installs these cross members in all of the CSX cars as the anchor point for shoulder belts and he certainly does a quality job with his cars (the conversation was actually about extra space he allows for in his tonneau covers to accommodate the cross member, so I was less focused on the seat belts).
I will have to check out how my current lap belts are anchored and then my options for 5 pt belts. In the meantime I am open to all suggestions and will report back with what I find.
www.partskeeper.com
01-24-2010, 07:51 PM
MD
Thanks for the photos, that is helpful and is a good option. My guess is that I'll end up with something anchored to the cowl hoop.
Hey one other question - where did the original CSX comp cars anchor their belts and what belts did they use?
www.partskeeper.com
01-24-2010, 09:17 PM
For more than lap belts, some of the original Comps had a crossbar that was positioned about halfway up the rollbar, behind the seat. It was an add-on, bolted not welded.
Several other shots of Comp cars also show a bolt-in eyelet on the lower bulkhead, also behind the seat, probably at a point where they could pick up a frame point behind the bulkhead.
01-25-2010, 12:22 AM
I run the cross bar set up on my CSX and so did Dick Smith when he was around racing his Cobra. I am also running a 5 point belt setup. My belts are from Crow.
Morgan LeBlanc
Fresno CA
01-25-2010, 07:40 AM
MD
Thanks for the pic, that's helpful.
www.partskeeper.com
01-25-2010, 08:59 AM
I wonder if anyone had tried that bolt on inside the cockpit as Ron says they did back in the day. The seat is really off center to the roll bar and I would think one of the eyes would be on the inside and one on the outside. Morgan that's a good shot of you and yours.
01-25-2010, 10:33 AM
If I had to use cross members on the roll bars for my shoulder belts it would be very uncomfortable for both the passenger and driver. They just don't line up properly on ERA cars.
01-25-2010, 10:39 AM
Thanks Mickmate,
Doug, you just want to take some measurements when you go this route. Get the cross bar as low as possible. Also note the loops are on the outside of the roll bar hoop on my CSX. Some people will run them on the inside but i would recommend against that.
Morgan LeBlanc
Fresno CA
01-25-2010, 10:46 AM
Banned
I use the standard Finishline component that I smoothed the welds on and had triple-chrome plated to match the hoop. I use the offset mounts to center the straps to my body. I'm also 6'3" so the mounting points are neither too far above or below my shoulder height. Too low and you can cause injury to your spine. Too high and it negates the safety. The original mounting point (to the frame) can still be seen just above the seat. I also use a crotch strap that is mounted to the floor bracing, so it's a true 5-point system.
-Dean
01-25-2010, 01:10 PM
MD
Why, do you recommend against the inside? It seems like Mickmate has that set-up. Is there a safety reason or just personal comfort?
www.partskeeper.com
01-25-2010, 01:12 PM
MD
Originally Posted by RedBarchetta
I'm also 6'3" so the mounting points are neither to far above or below my shoulder height.
I am 6'2", so this set-up might work for me as well. Any idea if the cross member scratches up the roll bar a lot so you can't really take it off once you've gone this direction?
www.partskeeper.com
01-25-2010, 01:19 PM
Banned
Doug, there is a thin rubber liner that slips between the clamps and the roll-bar. You really don't notice it unless you are looking for them.
-Dean
01-25-2010, 01:20 PM
MD
Good to know, thanks.
www.partskeeper.com
