Old 09-10-2010, 06:39 PM
HYM810ANCE's Avatar
Cobra Make, Engine: Everett Morrison- 351C
Default Soft Top Frame
I am needing a soft top frame for a 1994 Everett-Morrison. Does anyone know where I might find one, or if any current manufacturers might make one that will work? Thanks
"If it isn't gaudy...I don't want it." ~Ginger
Old 09-10-2010, 06:41 PM
mickmate's Avatar
Check your measurements between the top ferrules and let me know what that is.
mickmate
http://www.actoncustom.com/
Old 09-13-2010, 10:28 PM
HYM810ANCE's Avatar
I'll get those to you tomorrow....Thanks.
Old 09-18-2010, 04:44 AM
Cobra Make, Engine: E-M ford small block
Before I head off to the garage here's what did: I cut two inches off the vertical post of the frame to lower the total top height of the top. The fabric top was worn and needed to be replaced and I had always had a problem with the top whipping in the wind. It changed the "top hat" look of the original top (no roll bar). Also, add some heavy fabric straps from front to back which loop and slide through the frame of the top. This was done in the MG and Triumph car tops. I found it reduces the wind whip and the car travels better at interstate speeds.
