Old 09-21-2010, 08:05 PM
kitcarbp's Avatar
Question How to Polish Cast Stainless Overiders
Does anyone have experience polishing cast stainless bumper overiders ? I spent about 20 minutes on one of them and realized the as cast surface scratches are pretty deep and I will need to go below 320 grit sandpaper to remove the scratches as cast. Once I get to 1500 grit paper then what ? Do I need to wet sand ? Tried Mothers Alum polish and it worked a bit. Advice?
Old 09-21-2010, 08:17 PM
You need to buff with a polisher and rouge. You know, like as simple as a buffing wheel on your grinder.
" It ain't no big deal"
Old 09-21-2010, 08:33 PM
FWB's Avatar
FWB FWB is offline
before you buff with rouge, use a beartex wheel ( scotchbrite wheel) it will smoothout the surface then you can put a luster on it with a buffer
Fred B
Old 09-22-2010, 04:45 AM
joyridin''s Avatar
I usually use this gritty red stuff on the buffing wheel first. Maybe after the ScotchBrite. Then I use the polishing bar and a different wheel for the final finish.
Old 09-22-2010, 05:00 PM
kitcarbp's Avatar
Thanks all , I also found the whole kit from Eastwood Company and their instructions are great and easy to follow.
Old 09-22-2010, 05:02 PM
FWB's Avatar
FWB FWB is offline
hey, i know....you can just follow the eastwood instructions.....hehehehhe.
Fred B
