Old 05-16-2011, 06:13 AM
Voyager's Avatar
Cobra Make, Engine: SPF #2920 w/ Keith Craft 408
Default hydraulic fitting sealant
After replacing my clutch slave cylinder this weekend, I’m getting a minor leak where the hydraulic hose screws into the slave. Can anyone recommend a sealant for the fitting threads?
Old 05-16-2011, 07:31 AM
PeteF's Avatar
Loctite has one in a small tube, called thread sealant. Says used by OEMs. It's a white sealant and worked for me. I got it at NAPA.
Old 05-16-2011, 07:32 AM
Replace the fittings. Hydraulics fittings don't leak if they are in even reasonable shape. They are not designed for the use of a sealant like a pipe tapered fitting.
Old 05-16-2011, 08:59 AM
DonC's Avatar
Another vote for replacing the fittings. They shouldn't leak if properly made and applied. If you're getting fluid out of the fittings, given the amount of pressure a hydraulic system creates, it's unlikely that thread sealant will correct the problem. I'm well aware that getting to some of the fittings can be a real nightmare but bite the bullet. When it comes to hydraulics you really want it done correctly.
DonC
Old 05-16-2011, 09:16 AM
undy's Avatar
The fitting that "typically" threads into the slave is a pipe thread (where it threads into the slave). In that case, new or old fitting, use a teflon paste. Don't use Teflon tape as it tends to shread and enter the fluid stream.
There are "straight thread" fittings that use a copper crush ring or some type of o-ring but as far as clutch slaves they tend to be the exception, not the rule.
Too many toys?? never!
Old 05-18-2011, 06:21 AM
Voyager's Avatar
Put the car back on jacks last night. The leak is coming from where the fitting screws into the slave. Can’t tighten the 90 degree elbow fitting anymore without getting a longer hydraulic line. Will get a new fitting, longer hydraulic line, and a backup slave (in case I’ve stripped the threads). Will also get some Teflon paste.
