SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 06-05-2011, 08:30 PM
Default Gasket between 9" 3rd member and housing
My Richmand Gear rebuild kit came with a thin cork gasket, to put between the rear end housing and the 3rd member. Considering the torque in a rear end, it seems to me that this gasket must take a pounding. I'm thinking of leaving the gasket out and using a sealant like "The Right Stuff." However leaving the gasket out will set the 3rd member an 1/8" or so deeper into the housing.
Anyone done this?
Advice Please.
Old 06-05-2011, 08:52 PM
Rick Parker's Avatar
There are some very good gaskets availabe for this application. They are made of a very heavy fiber type paper with rubber beads around the perimeter, and "claim" to be reusable.
Rick
Old 06-05-2011, 09:21 PM
Rick are you against just using the sealant with no gasket?
Old 06-05-2011, 09:25 PM
LuvDaBlues's Avatar
Summit: Raytech brand: 5107-R: $9.95
It's a rubber gasket that "fills in" irregularities on the housing or pumpkin. I use "Right Stuff" on the housing side, and bare on the pumpkin. I do not use synthetic gear oil, so it doesn't leak. It's a reusable gasket in case you goofed up on something.
Oops .... this is for a Ford 9".
Steve S
F-250 w/ 6.4 Diesel
Old 06-05-2011, 11:52 PM
lovehamr's Avatar
Stolen Avitar
That's what I do.
Won't matter a bit.
HTML code is On
