SUPPORT OUR SPONSOR
Old 09-22-2001, 12:31 AM
Cobra Make, Engine: SPF, 427 SO
With the ignition switch in the run position, use a test light and check to be sure you have power on both sides of the fusable link. If you don't have power on both sides, then this is your problem. You can check for sure by putting a jumper wire in place of the fusable link. If it runs, you know for sure that you need to replace the link.
HTML code is On
