Old 01-06-2012, 03:55 PM
Default Starter Problems. Please help!
Hey fellas. I just had my new (to me) SPF delivered and I LOVE IT! However, I have been experiencing some starting problems. It has a push button start and it is a 351 W Holly carbed setup. When I turn the ignition on, I give the throttle a little gas and then hit the button. Immediately I hear a starting noise, then it stops. When I take my finger off the button, I hear a noise again. I'll repeat this process eventually flooring the pedal (because I likely flooded the engine) and after a few button pushes it will sound like a start should, rrrr rrrr rrrr...then Vroom of the engine. Once started it seems to be running a little rich, but nothing too crazy.
So, do I have a bad starter, bad starter connection, or a carburetor problem? Thanks for your help!
Old 01-06-2012, 05:12 PM
Could be a connection to the starter button but sounds like a starter button issue to me.
The running rich could be just a simple carb adjustment or it could be from flooding the engine. Is it running rich just after you start it only or all of the time.
Terry
Old 01-06-2012, 05:29 PM
Also check the tightness of your ground wires, especially at the battery. These cars can rattle and loosen cables, etc.
Old 01-06-2012, 06:54 PM
Archrms's Avatar
Cobra Make, Engine: Superformance SPF#2572, 427 S/O 2X4
How did you wire the push start button? Did you use a relay? Are you still using the key to energize the system? What type of push start button did you use? A little more info and a few pics would help
Peace through superior firepower...or is it horsepower? Either way, more is always better!
Old 01-07-2012, 02:09 PM
Rick Parker's Avatar
Is the starter motor operating when the button is pushed? Is it a matter of the starter motor pinion not meshing with the flywheel? If so, look at mechnical parts of the starter and solenoid.
Old 01-09-2012, 08:02 AM
I think I have it figured out. When I barely push the button in, it gets the starter going. If I push it in all the way, it does not work properly and makes a quick chirp and that's it. So, that tells me it is probably the button itself. Thanks for the help.
