SUPPORT OUR SPONSOR
Old 10-22-2001, 11:49 AM
Wayne Maybury's Avatar
Canadian Gashole
Cobra Make, Engine: Johnex 427 S/C, 351W, 472 HP, 444 lbs. torque
Question A question on heaters
I have installed a heater in my Johnex but I haven't hooked up the hoses yet. What type of valve do you use to cut off the coolent flow. I have already installed AN fittings on the heater since I plan on using all AN fittings and hose.
I want a cutoff valve that works well but also something that doesn't look out of place. A ball valve from the hardware store will work but it is not being considered, because of it's looks.
Regards,
Wayne
Don't get caught dead, sitting on your seat belt.
Old 10-26-2001, 08:45 PM
Okiesnake's Avatar
Cobra Make, Engine: Unique 427SC, 351W
You might try Vintage Air. I hooked up a manual carb cable to open and close the valve from inside the cockpit.
Old 10-26-2001, 08:53 PM
Okiesnake's Avatar
Vintage Air web site is http://www.vintageair.com
You might want to order a catalog.
Old 10-27-2001, 10:18 AM
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Would attach photo but mine is from same source, looks the same, and works just fine. Virtually any manual valve with the right size hose ends, usually 5/8", will work and can be had from your local auto supply store too.
The valve you don't want to use is a vacuum valve. It's either on, or off, and car is then too hot, or too cold.
Old 10-28-2001, 06:25 AM
Canadian Gashole
Thanks guys. I will order a catalog from vintage air.
Someone always comes through with an answer here at CC.
Regards
Wayne
HTML code is On
